求助引脚分配问题
求助引脚分配问题
我用的是的 EP1C120Q240C8 。
我想测试一下 RCE-01(Red Cyclone Extension) 上的四位七段数码管,结果发现四位七段数码管的FPGA对应的管脚号与主开发板RCM上的Flash的地址信号完全一样,所以我在分配。在 compilation 的后,提示错误:
Error: Can't place node SEVEN_SEG_PIO[15] in location PAD_80 because location already occupied by node FLASH_A[8]
Error: Can't place node SEVEN_SEG_PIO[14] in location PAD_112 because location already occupied by node FLASH_A[16]
Error: Can't place node SEVEN_SEG_PIO[13] in location PAD_90 because location already occupied by node FLASH_A[15]
Error: Can't place node SEVEN_SEG_PIO[12] in location PAD_89 because location already occupied by node FLASH_A[14]
Error: Can't place node SEVEN_SEG_PIO[11] in location PAD_88 because location already occupied by node FLASH_A[13]
Error: Can't place node SEVEN_SEG_PIO[10] in location PAD_108 because location already occupied by node FLASH_A[18]
Error: Can't place node SEVEN_SEG_PIO[9] in location PAD_109 because location already occupied by node FLASH_A[19]
Error: Can't place node SEVEN_SEG_PIO[8] in location PAD_110 because location already occupied by node FLASH_A[20]
Error: Can't place node SEVEN_SEG_PIO[7] in location PAD_80 because location already occupied by node FLASH_A[8]
Error: Can't place node SEVEN_SEG_PIO[6] in location PAD_112 because location already occupied by node FLASH_A[16]
Error: Can't place node SEVEN_SEG_PIO[5] in location PAD_90 because location already occupied by node FLASH_A[15]
Error: Can't place node SEVEN_SEG_PIO[4] in location PAD_89 because location already occupied by node FLASH_A[14]
Error: Can't place node SEVEN_SEG_PIO[3] in location PAD_88 because location already occupied by node FLASH_A[13]
Error: Can't place node SEVEN_SEG_PIO[2] in location PAD_108 because location already occupied by node FLASH_A[18]
Error: Can't place node SEVEN_SEG_PIO[1] in location PAD_109 because location already occupied by node FLASH_A[19]
Error: Can't place node SEVEN_SEG_PIO[0] in location PAD_110 because location already occupied by node FLASH_A[20]
另外:这个四位七段数码管每个管有个使能信号LED_ANi (i=0,1,2,3)(低电平有效),而LED_j(j=A,B,B,D,E,F,G,DP)是公用的,既然管脚不能冲突,那我如何让它们复用??
请高人指点,谢谢!
当然是加片选信号了。至于数码管的数据信号与FLASH的数据信号分配一次就可以了,何必再对管脚另起名字呢。实在不习惯可以用DATA[]来表示数据就是了。
爱,不是激情的随口
        情,不是瞬间的感动
谢谢!
