cf卡测试程序问题
cf卡测试程序问题
昨天终于把cf卡和up3板子连接的小板子做出来了 我用了up3板子上自带的那个cf测试程序 可是测试的时候结果就一“|”从右到左的晃动 没有其他东西 不知道为什么 程序如下: #include #include "io.h" #include int main() { unsigned int i, count, seldrv, present, pwr_on; unsigned short data[2055]; unsigned long j; unsigned char st_com,sel_drive; #define CF_PRESENCE_CHK_REG_ADDRESS 0x00000880 #define CF_POWER_ON_REG_ADDRESS 0x00000890 #define CF_DATA_REG_ADDRESS 0x06000000 #define CF_ERROR_REG_ADDRESS 0x06000004 #define CF_SEC_CNT_REG_ADDRESS 0x06000008 #define CF_SEC_NO_REG_ADDRESS 0x0600000C #define CF_CYL_L_REG_ADDRESS 0x06000010 #define CF_CYL_H_REG_ADDRESS 0x06000014 #define CF_SELECT_DRIVE_REG_ADDRESS 0x06000018 #define CF_STATUS_CMD_REG_ADDRESS 0x0600001C #define CF_ALT_STATUS_REG_ADDRESS 0x06000038 #define OFFSET 0x00000000 unsigned short result=0; //-------------------------------------------------------------- //Copact FLash presence cheching //-------------------------------------------------------------- present =IORD(CF_PRESENCE_CHK_REG_ADDRESS,OFFSET); if(present != 0) { printf("Waiting for the Compact Flash Card to be inserted ......\n"); } while(present != 0) { present =IORD(CF_PRESENCE_CHK_REG_ADDRESS,0); printf(""); } printf("\n\nCompact Flash is detected ......\n\n\n"); //Power the device IOWR(CF_POWER_ON_REG_ADDRESS,OFFSET,0x00000001); while(1) { printf("\n*************** What do u want to do *****************\n"); printf(" \n"); printf("(1) : Get Device info \n"); printf("(2) : Removing the Compact Flash & Exit the Application \n"); printf("\n"); printf("********************************************************\n"); printf(" Enter your selection No:"); scanf("%d", &count); switch(count) { case 1: IOWR_8DIRECT(CF_STATUS_CMD_REG_ADDRESS,OFFSET,0xEC); //Wait untile device ready bit not set st_com =IORD_8DIRECT(CF_STATUS_CMD_REG_ADDRESS,OFFSET); while((st_com&0x08)!=0x08) { st_com =IORD_8DIRECT(CF_STATUS_CMD_REG_ADDRESS,OFFSET); } printf("CF_STATUS_CMD_REG_ADDRESS = %x\n", st_com); for(i=0;i<256;i++) { data = IORD_16DIRECT(CF_DATA_REG_ADDRESS,OFFSET); } for(i=0;i<256;i++) { printf("Word %d %04x\n",i,data); } break; case 2: IOWR(CF_POWER_ON_REG_ADDRESS,OFFSET,0x00000000); printf(" \n\n --------------------------------------------\n"); printf(" Now its safe to remove the CompactFlash Card\n"); printf(" --------------------------------------------\n\n"); exit(0); default: //exit(0); break; } } return 0 大家知道有个system.h文件里面#define好多数 其中cf的定义了ctl和ide的base “ #define CF_DATA_REG_ADDRESS 0x06000000 #define CF_ERROR_REG_ADDRESS 0x06000004 #define CF_SEC_CNT_REG_ADDRESS 0x06000008 #define CF_SEC_NO_REG_ADDRESS 0x0600000C #define CF_CYL_L_REG_ADDRESS 0x06000010 #define CF_CYL_H_REG_ADDRESS 0x06000014 #define CF_SELECT_DRIVE_REG_ADDRESS 0x06000018 #define CF_STATUS_CMD_REG_ADDRESS 0x0600001C #define CF_ALT_STATUS_REG_ADDRESS 0x06000038 #define OFFSET 0x00000000” 难道是这里需要改动吗
342
不知道哪位能不能提供一个up3板子的cf测试程序啊
342
不知测CF卡的什么内容?
美国 logicube 的硬盘拷贝机, 专业用于硬盘诊断和硬盘复制, 可选配各种接口,用于检测各种硬盘.  选配CF卡接口,可以检测各种CF卡的各种参数.
www.logicube.cn
生活工作两不误
