Picasso使用简介及分析(9)
Picasso使用简介及分析(9)
10. 当从硬盘或者服务器获取Bitmap之后,就可以通过Action来执行各种自定义的callback了
    //dispatcher.dispatchComplete()用来处理bitmap成功获取后的逻辑,
    //经过一系列的转发,最终逻辑是在Picasso类里的complete方法中执行的。
    void complete(BitmapHunter hunter) {
      Action single = hunter.getAction();
      List<Action> joined = hunter.getActions();
      boolean hasMultiple = joined != null && !joined.isEmpty();
      boolean shouldDeliver = single != null || hasMultiple;
      if (!shouldDeliver) {
          return;
      Uri uri = hunter.getData().uri;
      Exception exception = hunter.getException();
      Bitmap result = hunter.getResult();
      LoadedFrom from = hunter.getLoadedFrom();
      if (single != null) {
        deliverAction(result, from, single);
      if (hasMultiple) {
        //noinspection ForLoopReplaceableByForEach
        for (int i = 0, n = joined.size(); i < n; i++) {
          Action join = joined.get(i);
          deliverAction(result, from, join);
      if (listener != null && exception != null) {
         listener.onImageLoadFailed(this, uri, exception);
    private void deliverAction(Bitmap result, LoadedFrom from, Action action) {
      if (action.isCancelled()) {
        return;
      if (!action.willReplay()) {
        targetToAction.remove(action.getTarget());
      if (result != null) {
        if (from == null) {
            throw new AssertionError("LoadedFrom cannot be null.");
        //这里的action就是前面提到的ImageViewAction,其他还有RemoteViewsAction,TargetAction等
        action.complete(result, from);
      } else {
        action.error();
