QG8的I2C问题求救
popfan
2009-7-16 23:58
QG8的I2C问题求救
最近在调试QG8的I2C模块,调试了很久都没成功,程序老是停在等待ACK " while(IICS_RXAK); "的位置,也就是QG8没有收到从端的ACK信号. 手册都看遍了,觉得没有什么错误啊,这里把程序贴出来,大家帮忙看看吧,万分感谢!!!
void main(void) {
//ICGTRM=0X80;
SOPT1_COPE = 0; //disable WatchDog
/* include your code here */
SCI_INIT();
Port_INIT();
PTAD_PTAD0 = 0;
I2c_init();
delay(100);
PTAD_PTAD0 = 1;
delay(100);
EnableInterrupts; /* enable interrupts */
WriteBytesI2C(BH1710_ADDRESS,0) ;
while(1) {
void WriteBytesI2C(unsigned char slaveAddress,char data)
char Temp;
Temp = 0x00;
Temp = slaveAddress<<1;
while(IICS_BUSY==1)
IICC_MST = 1;
IICC_TXAK = 0;
IICS_IICIF = 1;
IICC_TX = 1; /* Select Transmit Mode 发送,伴随着下面MST从0变1 */
IICD = Temp; /* Send slave device selected address */
while(!IICS_IICIF);
IICS_IICIF = 1;
while(IICS_RXAK);
IICD = data;
while(!IICS_IICIF);
IICS_IICIF = 1;
while(IICS_RXAK);
IICC_MST = 0;
void Port_INIT(void){
//----- Initialized the other pin
PTADD_PTADD0 = 1; // set pin as output
PTAPE_PTAPE0 = 1; //enable internal pull up
PTADS_PTADS0 = 1; // enable how output driver
PTAD_PTAD0 = 1; // default value is high
void I2c_init(void)
/* Configure interfaces. Set our IIC adress. */
IICC_IICEN = 1; /* Enable IIC_module */
IICC_TXAK = 0;
IICC_MST = 0;
IICA =0x00; /* IIC Address */
IICF = 0x40; /* Set IIC frequency */
I2C_STEP = IIC_READY_STATUS;
void SCI_INIT(void) {
// SCIBD =4530000/16/scibandrate; //设置波特率
SCIBD = 29;
SCIC1=0x00;
SCIC2=0x2C;//使能接受中断
void delay(int x){
int i,j;
for(i=0;i<x;i++) {
for(j=0;j<100;j++)
strongchen
2009-7-21 14:52
你有没有看过信号波形,从机是否发出了ACK应答信号?
ma.jh
2009-7-28 12:47
我的IIC挂了一个接口芯片可以通,但由加挂一个24C64后,无法与后者相通,表现与楼主一样,郁闷。
Henry_Yu
2009-8-1 22:47
仔细查查Slave的地址对不对!
