这是我写的count16程序,但是不能仿真,老师说要加reset
但是我不会~!请高手帮我修改下~!谢谢~!
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following lines to use the declarations that are
-- provided for instantiating Xilinx primitive components.
--library UNISIM;
--use UNISIM.VComponents.all;
entity count16 is
port(clk:in std_logic;
D,C,B,Aut std_logic);
end count16;
architecture Behavioral of count16 is
signal count_4:std_logic_vector(3 downto 0);
begin
process(clk) --进程敏感信号
begin
if(clk'event and clk='1') then --时钟上升沿触发
if(count_4="1111") then
count_4<="0000";
else
count_4<=count_4+1;
end if;
end if;
end process;
D<=count_4(0); --最低位从D输出
C<=count_4(1); --次低位从C输出
B<=count_4(2); --次高位从B输出
A<=count_4(3); --最高位从A输出
end Behavioral;
先在这里谢谢大虾们了~!
我是刚刚学这个的,请不要笑话~~~~~~!!!
