点Programmer后提示:
File d:/experimentboard/nopain/niossmall_time_limited.sof contains one or more time_limited megafuntion time expires.Refer to the messages
window for evaluation time details. 点确定,下载完sof文件后,出现了如图所示的提示:click concel to stop using opencore plus ip点击concel后,试验箱中不在进行程序的运行。问题出在那里呢?是license的问题么?如何解决啊?
还有前面提到的双永管脚绑定的问题:我用的Altera 的cyclone ep1c6q240c8,将其
24号管脚及37号管脚与PIO输出绑定后,进行编译时,出现如下提示:
Info: Device migration not selected. If you intend to use device migration later, you may need to change the pin assignments as they may be incompatible with other devices.
Info: Device EP1C12Q240C8 is compatible Error: Can't place node ~nCSO~ in location PAD_20 because location already occupied by node display[2]
Error: Can't place node ~ASDO~ in location PAD_30 because location already occupied by node display[3]
Info: No exact pin location assignment(s) for 4 pins of 27 total pins
Info: Pin altera_reserved_tdo not assigned to an exact location on the device
Info: Pin altera_reserved_tms not assigned to an exact location on the device
Info: Pin altera_reserved_tck not assigned to an exact location on the device
Info: Pin altera_reserved_tdi not assigned to an exact location on the device
Error: Can't fit design in device
Error: Quartus II Fitter was unsuccessful. 3 errors, 0 warnings
Error: Processing ended: Sat Apr 23 11:32:39 2005
Error: Elapsed time: 00:00:03
Error: Quartus II Full Compilation was unsuccessful. 3 errors, 74 warnings
我看了一下:Assignment ->devices->devices &pins->双用引脚无法进行配置。而
公司发过来的例程中却可以啊?[em27]作者: iceworld 时间: 2005-5-10 01:27
to icesword
我是初学者,用的是quartus2 4.0和NIOS open-core plus development kit 3.10
编译时报错为
Error: Can't find feature line for core 6AFA_1001 in current license
Error: Can't compile design containing encrypted file C:/quartus/example0/sopc_parameters_0.tdf -- current license does not allow this file to be opened
Error: Node instance the_sopc_parameters_0 instantiates undefined entity sopc_parameters_0
请问是NIOS license 的问题吗?怎么解决?作者: roxette1979 时间: 2005-7-25 18:06
