3 拓扑结构的抽取与仿真 Extracting and Simulating Topologies
3.1 Pre-Route Extraction Setup—Default Model Selection.
3.2 Pre-Route Extraction Setup—Unrouted Interconnect
3.3 Pre-Route Template Extraction
3.4 SQ Signal Explorer Expert
3.5 Analysis Preferences
3.6 SigWave
3.7 Delay Measurements
第二阶段
4 确定和施加约束 Determining and Adding ConstraintsSolution
4.1 Solution SpaceAnalysis: Step 1 to 6
4.2 Parametric Sweeps.
4.3 Constraints :
Topology Template Constraints
Switch/Settle Constraints
Assigning the Prop Delay Constraints
Impedance Constraint
Relative Propagation Delay Constraint
Diff Pair Constraints
Max Parallel Constraint
Wiring Constraint
User-Defined Constraint
Signal Integrity Constraints
4.4 Usage of Constraints Defined in Topology Template
5 模板应用和基于约束的布局
Template Applications and Constraint-Driven Placement
5.1 Creating a Topology
5.2 Wiring the Topology
5.3 TLines and Trace Models
5.4 Coupled Traces
5.5 RLGC Matrix of Coupled Trace Models
5.6 Crosstalk Simulation in SQ Signal Explorer Expert
5.7 Simulating with Coupled-Trace Models
5.8 Sweep Simulation Results with Coupled-Trace Models
5.9 Extracting a Topology Using the Constraint Manager
5.10 Electrical Constraint Set
5.11 Applying Electrical CSet
5.12 Worksheet Analysis
5.13 Spacing and Physical Rule Sets
5.14 Electrical Rule Set
第三阶段
6 基于约束的布线 Constraint-Driven Routing
6.1 Manual Routing
6.2 Routing with the SPECCTRA Smart Route
6.3 Driving Constraints in Routing
7 布线后的DRC检查和分析 Post-Route DRC and Analysis
7.1 Post-Route Analysis
7.2 SigNoise
7.3 Reflection Simulation
7.4 Reflection Waveform Analysis
7.5 Comprehensive Simulation
7.6 Crosstalk Simulation
7.7 Crosstalk Analysis
7.8 Simultaneous Switching Noise Simulation
7.9 SSN Waveform Analysis
7.10 System-Level Analysis
7.11 A Complete Design Link
7.12 Initialize Design Link
8 差分信号设计 Differential Pair Design Exploration
8.1 Types of Differential Pairs in SPECCTRAQuest
8.2 Create Differential Pair Using SPECCTRAQuest
8.3 Create Differential Pair Using Constraint Manager
8.4 Assigning Differential Pair Signal Models
8.5 Preference to Extract Unrouted Differential Pair Topology
8.6 Extracting Unrouted Differential Pair Topology
8.7 Custom Stimulus to Analyze Differential Pair Topology
8.8 Differential Pair Topology Analysis
8.9 Coupled Trace Model and Differential Pair Topology
8.10 Layout Cross-section Editor
8.11 Differential Pair Constraints
8.12 Differential Pair Constraints in the Constraint Manager
8.13 Differential Pair Analysis in the Constraint Manager
8.14 Post Route Extraction
