请教各位大师个问题,帮忙解决个问题!辣手啊! | |
![](http://www.eefocus.com/images/bbs/smilies/010.gif) ![](http://www.eefocus.com/images/bbs/smilies/010.gif)
本人是新手,刚开始学习单片机,编了个程序,可是结果有点失望!所以请教大师们!
功能如下:
利用动态扫描和定时器1在数码管上显示出从765432开始以1/10秒的速度往下递减直至765398并
保持显示此数,与此同时利用定时器0以500MS速度进行流水灯从上至下移动,当数码管上数减到停止时,
实验板上流水灯也停止然后全部开始闪烁,
3秒后(用T0定时)流水灯全部关闭、数码管上显示出“HELLO”。到此保持住。
程序如下:
#include <reg52.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,
0x76,0x79,0x38,0x3f,0};
uchar temp,t0,t1,bai,shi,ge,flag,flag1;
uint shu;
void init();
void display(uchar,uchar,uchar,uchar,uchar,uchar);
void delay(uint z)
uint t1,y;
for(t1=z;t1>0;t1--)
for(y=110;y>0;y--);
void main()
init();
while(1)
if(flag1!=1)
display(7,6,5,bai,shi,ge);
else
display(16,17,18,18,19,20);
void init()
shu=432;
temp=0xfe;
P1=temp;
TMOD=0x11;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TH1=(65536-50000)/256;
TL1=(65536-50000)%256;
EA=1;
ET0=1;
ET1=1;
TR0=1;
TR1=1;
void timer0() interrupt 1
t0++;
if(flag!=1)
if(t0==10)
t0=1;
temp=_crol_(temp,1);
P1=temp;
else
if(t0%4==0)
P1=~P1;
if(t0==60)
TR0=0;
P1=0xff;
flag1=1;
void timer1() interrupt 3
t1++;
if(t1==2)
t1=0;
shu--;
bai=shu/100;
shi=shu%100/10;
ge=shu%10;
if(shu==398)
TR0=0;
TR0=1;
flag=1;
t0=0;
P1=0xff;
TR1=0;
void display(uchar aa,uchar bb,uchar cc,uchar ba,uchar sh,uchar g)
dula=1;
P0=table[aa];
dula=0;
P0=0xff;
wela=1;
P0=0xfe;
wela=0;
delay(1);
dula=1;
P0=table[bb];
dula=0;
P0=0xff;
wela=1;
P0=0xfd;
wela=0;
delay(1);
dula=1;
P0=table[cc];
dula=0;
P0=0xff;
wela=1;
P0=0xfb;
wela=0;
delay(1);
dula=1;
P0=table[ba];
dula=0;
P0=0xff;
wela=1;
P0=0xf7;
wela=0;
delay(1);
dula=1;
P0=table[sh];
dula=0;
P0=0xff;
wela=1;
P0=0xef;
wela=0;
delay(1);
dula=1;
P0=table[g];
dula=0;
P0=0xff;
wela=1;
P0=0xdf;
wela=0;
delay(1);
仿真图如下:
![](http://www.eefocus.com/include/picture/500/400/data/myspace/38/192322/bbs/2010-07-21/1279700332_870f8899.jpg)
程序在KEIL软件上编译没有出错!
流水灯已经实现,数码管的功能没有实现,乱码了!右边两个是74HC573
仿真软件是proteus7 professional
