typedef unsigned long int uint32; /* Unsigned 32 bit value */
typedef unsigned short uint16; /* Unsigned 16 bit value */
typedef unsigned char uint8; /* Unsigned 8 bit value */
typedef signed long int int32; /* Signed 32 bit value */
typedef signed short int16; /* Signed 16 bit value */
typedef signed char int8; /* Signed 8 bit value */
//下面的不建议使用
typedef unsigned char byte; /* Unsigned 8 bit value type. */
typedef unsigned short word; /* Unsinged 16 bit value type. */
typedef unsigned long dword; /* Unsigned 32 bit value type. */
typedef unsigned char uint1; /* Unsigned 8 bit value type. */
typedef unsigned short uint2; /* Unsigned 16 bit value type. */
typedef unsigned long uint4; /* Unsigned 32 bit value type. */
typedef signed char int1; /* Signed 8 bit value type. */
typedef signed short int2; /* Signed 16 bit value type. */
typedef long int int4; /* Signed 32 bit value type. */
typedef signed long sint31; /* Signed 32 bit value */
typedef signed short sint15; /* Signed 16 bit value */
typedef signed char sint7; /* Signed 8 bit value */
#define outp(port, val) (*((volatile byte *) (port)) = ((byte) (val)))
#define outpw(port, val) (*((volatile word *) (port)) = ((word) (val)))
#define outpdw(port, val) (*((volatile dword *) (port)) = ((dword) (val)))
[2005-9-9添加]
19,使用一些宏跟踪调试
A N S I标准说明了五个预定义的宏名。它们是:
_ L I N E _
_ F I L E _
_ D A T E _
_ T I M E _
_ S T D C _
如果编译不是标准的,则可能仅支持以上宏名中的几个,或根本不支持。记住编译程序
也许还提供其它预定义的宏名。
_ L I N E _及_ F I L E _宏指令在有关# l i n e的部分中已讨论,这里讨论其余的宏名。
_ D AT E _宏指令含有形式为月/日/年的串,表示源文件被翻译到代码时的日期。
源代码翻译到目标代码的时间作为串包含在_ T I M E _中。串形式为时:分:秒。
如果实现是标准的,则宏_ S T D C _含有十进制常量1。如果它含有任何其它数,则实现是
非标准的。
可以定义宏,例如:
当定义了_DEBUG,输出数据信息和所在文件所在行
#ifdef _DEBUG
#define DEBUGMSG(msg,date) printf(msg);printf(“%d%d%d”,date,_LINE_,_FILE_)
#else
#endif
