Error! : Unable to load memory block at address 0x20000 from ELF file Debug/hell
o_world_9.elf
Fatal Error! : Memory map is not consistent with memory image file - check that
file 'Debug/hello_world_9.elf' is compiled and linked for system 'D:\altera\qdes
igns42\test\SysyemTop.ptf'作者: mage1982mage198 时间: 2005-7-3 00:13
