NUC100 Advance Line Selection Guide (medium density)
Part No. Flash SRAM I/O Timer Connectivity I2S Comp. PWM ADC RTC ISP Package Status*
(KB) UART SPI I2C USB LIN CAN ICP
NUC100LE3AN 128K 16K up to 35 4x32-bit 2 1 2 1 1 6 8x12-bit v v LQFP48 P
NUC100LD3AN 64K 16K up to 35 4x32-bit 2 1 2 1 1 6 8x12-bit v v LQFP48 P
NUC100RE3AN 128K 16K up to 49 4x32-bit 3 2 2 1 2 6 8x12-bit v v LQFP64 P
NUC100RD3AN 64K 16K up to 49 4x32-bit 3 2 2 1 2 6 8x12-bit v v LQFP64 P
NUC100VE3AN 128K 16K up to 80 4x32-bit 3 4 2 1 2 8 8x12-bit v v LQFP100 P
NUC100VD3AN 64K 16K up to 80 4x32-bit 3 4 2 1 2 8 8x12-bit v v LQFP100 P
NUC100VD2AN 64K 8K up to 80 4x32-bit 3 4 2 1 2 8 8x12-bit v v LQFP100 P
*Status: P= Mass Production, S=Samples, UD=Under Development, UD (Time)= Under Development(Ready Time), EOL=End of life.
NUC100 Advance Line Selection Guide (low density)
NUC100LD2AN 64K 8K up to 35 4x32-bit 2 1 2 1 1 4 8X12-Bit v v LQFP48 P
NUC100LD1AN 64K 4K up to 35 4x32-bit 2 1 2 1 1 4 8X12-Bit v v LQFP48 P
NUC100LC1AN 32K 4K up to 35 4x32-bit 2 1 2 1 1 4 8X12-Bit v v LQFP48 P
NUC100RD2AN 64K 8K up to 49 4x32-bit 2 2 2 1 2 4 8X12-Bit v v LQFP64 P
NUC100RD1AN 64K 4K up to 49 4x32-bit 2 2 2 1 2 4 8X12-Bit v v LQFP64 P
NUC100RC1AN 32K 4K up to 49 4x32-bit 2 2 2 1 2 4 8X12-Bit v v LQFP64 P
NUC120 USB Line Selection Guide (Medium Density)
NUC120LE3AN 128K 16K up to 31 4x32-bit 2 1 2 1 1 1 4 8x12-bit v v LQFP48 P
NUC120LD3AN 64K 16K up to 31 4x32-bit 2 1 2 1 1 1 4 8x12-bit v v LQFP48 P
NUC120RE3AN 128K 16K up to 45 4x32-bit 2 2 2 1 1 2 6 8x12-bit v v LQFP64 P
NUC120RD3AN 64K 16K up to 45 4x32-bit 2 2 2 1 1 2 6 8x12-bit v v LQFP64 P
NUC120VE3AN 128K 16K up to 76 4x32-bit 3 4 2 1 1 2 8 8x12-bit v v LQFP100 P
NUC120VD3AN 64K 16K up to 76 4x32-bit 3 4 2 1 1 2 8 8x12-bit v v LQFP100 P
NUC120VD2AN 64K 8K up to 76 4x32-bit 3 4 2 1 1 2 8 8x12-bit v v LQFP100 P
NUC120 USB Line Selection Guide (low density)
Part No. Flash SRAM I/O Timer Connectivity I2S Comp. PWM ADC RTC ISP Package Stutas*
NUC120LD2AN 64K 8K up to 31 4x32-bit 2 1 2 1 1 1 4 8X12-Bit v v LQFP48 P
NUC120LD1AN 64K 4K up to 31 4x32-bit 2 1 2 1 1 1 4 8X12-Bit v v LQFP48 P
NUC120LC1AN 32K 4K up to 31 4x32-bit 2 1 2 1 1 1 4 8X12-Bit v v LQFP48 P
NUC120RD2AN 64K 8K up to 45 4x32-bit 2 2 2 1 1 2 4 8X12-Bit v v LQFP64 P
NUC120RD1AN 64K 4K up to 45 4x32-bit 2 2 2 1 1 2 4 8X12-Bit v v LQFP64 P
NUC120RC1AN 32K 4K up to 45 4x32-bit 2 2 2 1 1 2 4 8X12-Bit v v LQFP64 P
NUC130 Automotive Line Selection Guide
NUC130LE3AN 128K 16K up to 35 4x32-bit 3 1 2 2 1 1 1 4 8x12-bit v v LQFP48 P
NUC130LD3AN 64K 16K up to 35 4x32-bit 3 1 2 2 1 1 1 4 8x12-bit v v LQFP48 P
NUC130LD2AN 64K 8K up to 35 4x32-bit 3 1 2 2 1 1 1 4 8x12-bit v v LQFP48 P
NUC130RE3AN 128K 16K up to 49 4x32-bit 3 2 2 2 1 1 2 6 8x12-bit v v LQFP64 P
NUC130RD3AN 64K 16K up to 49 4x32-bit 3 2 2 2 1 1 2 6 8x12-bit v v LQFP64 P
NUC130RD2AN 64K 8K up to 49 4x32-bit 3 2 2 2 1 1 2 6 8x12-bit v v LQFP64 P
NUC130VE3AN 128K 16K up to 80 4x32-bit 3 4 2 2 1 1 2 8 8x12-bit v v LQFP100 P
NUC130VD3AN 64K 16K up to 80 4x32-bit 3 4 2 2 1 1 2 8 8x12-bit v v LQFP100 P
NUC130VD2AN 64K 8K up to 80 4x32-bit 3 4 2 2 1 1 2 8 8x12-bit v v LQFP100 P
NUC140 Connectivity Line Selection Guide
NUC140LE3AN 128K 16K up to 31 4x32-bit 2 1 2 1 2 1 1 1 4 8x12-bit v v LQFP48 P
NUC140LD3AN 64K 16K up to 31 4x32-bit 2 1 2 1 2 1 1 1 4 8x12-bit v v LQFP48 P
NUC140LD2AN 64K 8K up to 31 4x32-bit 2 1 2 1 2 1 1 1 4 8x12-bit v v LQFP48 P
NUC140RE3AN 128K 16K up to 45 4x32-bit 3 2 2 1 2 1 1 2 4 8x12-bit v v LQFP64 P
NUC140RD3AN 64K 16K up to 45 4x32-bit 3 2 2 1 2 1 1 2 4 8x12-bit v v LQFP64 P
NUC140RD2AN 64K 8K up to 45 4x32-bit 3 2 2 1 2 1 1 2 4 8x12-bit v v LQFP64 P
NUC140VE3AN 128K 16K up to 76 4x32-bit 3 4 2 1 2 1 1 2 8 8x12-bit v v LQFP100 P
NUC140VD3AN 64K 16K up to 76 4x32-bit 3 4 2 1 2 1 1 2 8 8x12-bit v v LQFP100 P
NUC140VD2AN 64K 8K up to 76 4x32-bit 3 4 2 1 2 1 1 2 8 8x12-bit v v LQFP100 P
Contact us: NuMicro@nuvoton.com
