请教达人:xilinx SPI ip核 master模式 EDK下不工作
lance1
2010-12-2 22:44
主要操作:在EDK中设置xps_spi的输入输出(IP2INTC_Irpt ,SCK_O,MISO_I,SPISEL,SPLB_Clk,SS_O)。选用PowerPC作为CPU,移植linux,编写驱动(主要是修改寄存器)
现象:上电加载模块(.ko文件)后,未有SCLK信号,SS_O一直是高电平(即inactive状态)
疑问:不是只要在寄存器设定了他是master,硬件电路就会自动产生SPLB_Clk/C_SCK_RATIO 这个频率的SCLK么,真的不懂了,希望高手赐教啊~
附上mhs:
BEGIN xps_spi
PARAMETER INSTANCE = xps_spi_0
PARAMETER HW_VER = 2.00.b
PARAMETER C_SCK_RATIO = 96
PARAMETER C_BASEADDR = 0x83c18000
PARAMETER C_HIGHADDR = 0x83c1807f
BUS_INTERFACE SPLB = plb
PORT IP2INTC_Irpt = xps_spi_0_IP2INTC_Irpt
PORT SCK_O = xps_spi_0_SCK_O
PORT MISO_I = clk_500k
PORT SPISEL = net_vcc
PORT SPLB_Clk = sys_clk_s
PORT SS_O = xps_spi_0_SS_O
END
驱动中寄存器设置:
#define XSPI_CR_OFFSET 0x60 /* 16-bit Control Register */
#define XSPI_CR_ENABLE 0x02
#define XSPI_CR_MASTER_MODE 0x04
#define XSPI_CR_CPOL 0x00
#define XSPI_CR_CPHA 0x10
#define XSPI_CR_MODE_MASK (XSPI_CR_CPHA | XSPI_CR_CPOL)
#define XSPI_CR_TXFIFO_RESET 0x20
#define XSPI_CR_RXFIFO_RESET 0x40
#define XSPI_CR_MANUAL_SSELECT 0x00
#define XSPI_CR_TRANS_INHIBIT 0x100
#define XSPI_CR_LSB_FIRST 0x200 /*little endian*/
#define XSPI_SR_OFFSET 0x64 /* 8-bit Status Register */
#define XSPI_SR_RX_EMPTY_MASK 0x01 /* Receive FIFO is empty */
#define XSPI_SR_RX_FULL_MASK 0x02 /* Receive FIFO is full */
#define XSPI_SR_TX_EMPTY_MASK 0x04 /* Transmit FIFO is empty */
#define XSPI_SR_TX_FULL_MASK 0x08 /* Transmit FIFO is full */
#define XSPI_SR_MODE_FAULT_MASK 0x10 /* Mode fault error */
#define XSPI_TXD_OFFSET 0x68 /* 8-bit Data Transmit Register */
#define XSPI_RXD_OFFSET 0x6c /* 8-bit Data Receive Register */
#define XSPI_SSR_OFFSET 0x70 /* 32-bit Slave Select Register */
#define XIPIF_V123B_DGIER_OFFSET 0x1c /* IPIF global int enable reg */
#define XIPIF_V123B_GINTR_ENABLE 0x80000000
#define XIPIF_V123B_IISR_OFFSET 0x20 /* IPIF interrupt status reg */
#define XIPIF_V123B_IIER_OFFSET 0x28 /* IPIF interrupt enable reg */
#define XSPI_INTR_MODE_FAULT 0x01 /* Mode fault error */
#define XSPI_INTR_SLAVE_MODE_FAULT 0x02 /* Selected as slave while
* disabled */
#define XSPI_INTR_TX_EMPTY 0x04 /* TxFIFO is empty */
#define XSPI_INTR_TX_UNDERRUN 0x08 /* TxFIFO was underrun */
#define XSPI_INTR_RX_FULL 0x10 /* RxFIFO is full */
#define XSPI_INTR_RX_OVERRUN 0x20 /* RxFIFO was overrun */
#define XIPIF_V123B_RESETR_OFFSET 0x40 /* IPIF reset register */
#define XIPIF_V123B_RESET_MASK 0x0a /* the value to write */
附件:
xps_spi.rar
(2010-12-2 23:07, 637.79 KB) / 下载次数 594
http://bbs.eccn.com/attachment.php?aid=9547&k=2634424e56718fd127af69c6301845cb&t=1717324842&sid=97YnXq
