标题: STM32 SPI通信 [打印本页]
作者: 梦景    时间: 2011-9-7 23:10     标题: STM32 SPI通信
/******************** (C) COPYRIGHT 2007 STMicroelectronics ********************
* File Name          : main.c
* Author             : MCD Application Team
* Version            : V1.0
* Date               : 10/08/2007
* Description        : Main program body
* THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Local includes ------------------------------------------------------------*/
/* Private typedef -----------------------------------------------------------*/
typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
/* Private define ------------------------------------------------------------*/
#define BufferSize 32
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
SPI_InitTypeDef   SPI_InitStructure;
u8 SPI1_Buffer_Tx[BufferSize] = {0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,
                                 0x0A,0x0B,0x0C,0x0D,0x0E,0x0F,0x10,0x11,0x12,
                                 0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x1A,0x1B,
                                 0x1C,0x1D,0x1E,0x1F,0x20};
u8 SPI2_Buffer_Tx[BufferSize] = {0x51,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59,
                                 0x5A,0x5B,0x5C,0x5D,0x5E,0x5F,0x60,0x61,0x62,
                                 0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6A,0x6B,
                                 0x6C,0x6D,0x6E,0x6F,0x70};
u8 SPI1_Buffer_Rx[BufferSize], SPI2_Buffer_Rx[BufferSize];
u8 Tx_Idx = 0, Rx_Idx = 0, k = 0;
volatile TestStatus TransferStatus1 = FAILED, TransferStatus2 = FAILED;
volatile TestStatus TransferStatus3 = FAILED, TransferStatus4 = FAILED;
ErrorStatus HSEStartUpStatus;
/* Private functions ---------------------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
TestStatus Buffercmp(u8* pBuffer1, u8* pBuffer2, u16 BufferLength);
* Function Name  : main
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System clocks configuration ---------------------------------------------*/
  RCC_Configuration();
  /* NVIC configuration ------------------------------------------------------*/
  NVIC_Configuration();
  /* GPIO configuration ------------------------------------------------------*/
  GPIO_Configuration();
  /* 1st phase: SPI1 Master and SPI2 Slave */
  /* SPI1 Config -------------------------------------------------------------*/
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_LSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI1, &SPI_InitStructure);
  /* SPI2 Config -------------------------------------------------------------*/
  SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
  SPI_Init(SPI2, &SPI_InitStructure);
  /* Enable SPI1 */
  SPI_Cmd(SPI1, ENABLE);
  /* Enable SPI2 */
  SPI_Cmd(SPI2, ENABLE);
  /* Transfer procedure */
  while(Tx_Idx<BufferSize)
    /* Wait for SPI1 Tx buffer empty */
    while(SPI_GetFlagStatus(SPI1, SPI_FLAG_TXE)==RESET);
    /* Send SPI2 data */
    SPI_SendData(SPI2, SPI2_Buffer_Tx[Tx_Idx]);
    /* Send SPI1 data */
    SPI_SendData(SPI1, SPI1_Buffer_Tx[Tx_Idx++]);
    /* Wait for SPI2 data reception */
    while(SPI_GetFlagStatus(SPI2, SPI_FLAG_RXNE)==RESET);
    /* Read SPI2 received data */
    SPI2_Buffer_Rx[Rx_Idx] = SPI_ReceiveData(SPI2);
    /* Wait for SPI1 data reception */
    while(SPI_GetFlagStatus(SPI1, SPI_FLAG_RXNE)==RESET);
    /* Read SPI1 received data */
    SPI1_Buffer_Rx[Rx_Idx++] = SPI_ReceiveData(SPI1);
  /* Check the corectness of written dada */
  TransferStatus1 = Buffercmp(SPI2_Buffer_Rx, SPI1_Buffer_Tx, BufferSize);
  TransferStatus2 = Buffercmp(SPI1_Buffer_Rx, SPI2_Buffer_Tx, BufferSize);
  /* TransferStatus1, TransferStatus2 = PASSED, if the transmitted and received data
     are equal */
  /* TransferStatus1, TransferStatus2 = FAILED, if the transmitted and received data
     are different */
  /* 2nd phase: SPI1 Slave and SPI2 Master */
  /* SPI1 Re-configuration ---------------------------------------------------*/
  /* SPI2 Re-configuration ---------------------------------------------------*/
  /* Reset Tx_Idx, Rx_Idx indexes and receive tables values */
  Tx_Idx=0;
  Rx_Idx=0;
  for(k=0; k<BufferSize; k++)  SPI2_Buffer_Rx[k]=0;
  for(k=0; k<BufferSize; k++)  SPI1_Buffer_Rx[k]=0;
    /* Wait for SPI2 Tx buffer empty */
    while(SPI_GetFlagStatus(SPI2, SPI_FLAG_TXE)==RESET);
    SPI_SendData(SPI1, SPI1_Buffer_Tx[Tx_Idx]);
    SPI_SendData(SPI2, SPI2_Buffer_Tx[Tx_Idx++]);
    SPI1_Buffer_Rx[Rx_Idx] = SPI_ReceiveData(SPI1);
    SPI2_Buffer_Rx[Rx_Idx++] = SPI_ReceiveData(SPI2);
  TransferStatus3 = Buffercmp(SPI2_Buffer_Rx, SPI1_Buffer_Tx, BufferSize);
  TransferStatus4 = Buffercmp(SPI1_Buffer_Rx, SPI2_Buffer_Tx, BufferSize);
  /* TransferStatus3, TransferStatus4 = PASSED, if the transmitted and received data
     are equal */
  /* TransferStatus3, TransferStatus4 = FAILED, if the transmitted and received data
     are different */
  while (1)
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK/2 */
    RCC_PCLK2Config(RCC_HCLK_Div2);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
/* Enable peripheral clocks --------------------------------------------------*/
  /* GPIOA, GPIOB and SPI1 clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                         RCC_APB2Periph_SPI1, ENABLE);
  /* SPI2 Periph clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
* Function Name  : GPIO_Configuration
* Description    : Configures the different GPIO ports.
* Input          : None
* Output         : None
* Return         : None
  GPIO_InitTypeDef GPIO_InitStructure;
  /* Configure SPI1 pins: SCK, MISO and MOSI ---------------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Configure SPI2 pins: SCK, MISO and MOSI ---------------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
* Function Name  : NVIC_Configuration
* Description    : Configures NVIC and Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
* Function Name  : Buffercmp
* Description    : Compares two buffers.
* Input          : - pBuffer1, pBuffer2: buffers to be compared.
*                : - BufferLength: buffer's length
* Output         : None
* Return         : PASSED: pBuffer1 identical to pBuffer2
*                  FAILED: pBuffer1 differs from pBuffer2
  while(BufferLength--)
    if(*pBuffer1 != *pBuffer2)
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert_param error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert_param error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
* Version            : V1.0
* Date               : 10/08/2007
u8 SPI2_Buffer_Rx[BufferSize];
vu8 Tx_Idx = 0, Rx_Idx = 0;
volatile TestStatus TransferStatus = FAILED;
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* SPI1 configuration ------------------------------------------------------*/
  SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  /* SPI2 configuration ------------------------------------------------------*/
  SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Rx;
  /* Enable SPI1 TXE interrupt */
  SPI_ITConfig(SPI1, SPI_IT_TXE, ENABLE);
  /* Enable SPI2 RXNE interrupt */
  SPI_ITConfig(SPI2, SPI_IT_RXNE, ENABLE);
  /* Enable SPI2 */
  /* Enable SPI1 */
  while(Rx_Idx < BufferSize)
  TransferStatus = Buffercmp(SPI2_Buffer_Rx, SPI1_Buffer_Tx, BufferSize);
  /* TransferStatus = PASSED, if the transmitted and received data
     are equal */
  /* TransferStatus = FAILED, if the transmitted and received data
     are different */
  while (1)
* Input          : None
* Output         : None
* Return         : None
  RCC_DeInit();
  /* Enable HSE */
    /* HCLK = SYSCLK */
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
* Input          : None
* Output         : None
* Return         : None
  /* Configure SPI1 pins: SCK and MOSI ---------------------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;
  /* Configure SPI2 pins: SCK and MISO ---------------------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14;
* Description    : Configure the nested vectored interrupt controller.
* Input          : None
* Output         : None
* Return         : None
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
#endif
  /* 1 bit for pre-emption priority, 3 bits for subpriority */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  /* Configure and enable SPI1 interrupt -------------------------------------*/
  NVIC_InitStructure.NVIC_IRQChannel = SPI1_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Configure and enable SPI2 interrupt -------------------------------------*/
  NVIC_InitStructure.NVIC_IRQChannel = SPI2_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
* Output         : None
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
#ifdef  DEBUG
* Output         : None
* Return         : None
  /* Infinite loop */
  while (1)
#endif
* Version            : V1.0
* Date               : 10/08/2007
u16 SPI1_Buffer_Tx[BufferSize] = {0x0102,0x0304,0x0506,0x0708,0x090A,0x0B0C,
                                  0x0D0E,0x0F10,0x1112,0x1314,0x1516,0x1718,
                                  0x191A,0x1B1C,0x1D1E,0x1F20,0x2122,0x2324,
                                  0x2526,0x2728,0x292A,0x2B2C,0x2D2E,0x2F30,
                                  0x3132,0x3334,0x3536,0x3738,0x393A,0x3B3C,
                                  0x3D3E,0x3F40};
u16 SPI2_Buffer_Tx[BufferSize] = {0x5152,0x5354,0x5556,0x5758,0x595A,0x5B5C,
                                  0x5D5E,0x5F60,0x6162,0x6364,0x6566,0x6768,
                                  0x696A,0x6B6C,0x6D6E,0x6F70,0x7172,0x7374,
                                  0x7576,0x7778,0x797A,0x7B7C,0x7D7E,0x7F80,
                                  0x8182,0x8384,0x8586,0x8788,0x898A,0x8B8C,
                                  0x8D8E,0x8F90};
u16 SPI1_Buffer_Rx[BufferSize], SPI2_Buffer_Rx[BufferSize];
vu16 CRC1_Value = 0, CRC2_Value = 0;
TestStatus Buffercmp(u16* pBuffer1, u16* pBuffer2, u16 BufferLength);
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
  /* Enable SPI1 CRC calculation */
  SPI_CalculateCRC(SPI1, ENABLE);
  /* Enable SPI2 CRC calculation */
  SPI_CalculateCRC(SPI2, ENABLE);
  /* Enable SPI1 */
  /* Enable SPI2 */
  while(Tx_Idx < BufferSize-1)
  /* Send last SPI2_Buffer_Tx data */
  /* Enable SPI2 CRC transmission */
  SPI_TransmitCRC(SPI2);
  /* Send last SPI1_Buffer_Tx data */
  /* Enable SPI1 CRC transmission */
  SPI_TransmitCRC(SPI1);
  /* Wait for SPI1 last data reception */
  /* Read SPI1 last received data */
  /* Read SPI2 last received data */
  /* Wait for SPI1 data reception: CRC transmitted by SPI2 */
  /* Read SPI1 received CRC value */
  CRC1_Value = SPI_ReceiveData(SPI1);
  /* Wait for SPI2 data reception: CRC transmitted by SPI1 */
  /* Read SPI2 received CRC value */
  CRC2_Value = SPI_ReceiveData(SPI2);
  /* TransferStatus1, TransferStatus2 = PASSED, if the data transmitted and received
     are correct */
  /* TransferStatus1, TransferStatus2 = FAILED, if the data transmitted and received
     are different */
  while (1)
* Input          : None
* Output         : None
* Return         : None
  RCC_DeInit();
  /* Enable HSE */
    /* HCLK = SYSCLK */
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
* Input          : None
* Output         : None
* Return         : None
* Input          : None
* Output         : None
* Return         : None
#ifdef  VECT_TAB_RAM
#endif
* Output         : None
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
#ifdef  DEBUG
* Output         : None
* Return         : None
  /* Infinite loop */
  while (1)
#endif
* Version            : V1.0
* Date               : 10/08/2007
#define SPI1_DR_Address  0x4001300C
DMA_InitTypeDef  DMA_InitStructure;
u8 SPI2_Buffer_Tx[BufferSize] = {0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,
u8 SPI1_Buffer_Rx[BufferSize];
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* DMA Channel2 configuration ----------------------------------------------*/
  DMA_DeInit(DMA_Channel2);
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)SPI1_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SPI1_Buffer_Rx;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = BufferSize;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA_Channel2, &DMA_InitStructure);
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;
  /* Enable SPI2 NSS output for master mode */
  SPI_SSOutputCmd(SPI2, ENABLE);
  /* Enable SPI1 Rx request */
  SPI_DMACmd(SPI1, SPI_DMAReq_Rx, ENABLE);
  /* Enable SPI1 */
  /* Enable SPI2 */
  /* Enable DMA Channel2 */
  DMA_Cmd(DMA_Channel2, ENABLE);
  while(Tx_Idx<32)
    while(SPI_GetFlagStatus(SPI2, SPI_FLAG_TXE) == RESET);
  /* Wait for DMA channel2 transfer complete */
  while(!DMA_GetFlagStatus(DMA_FLAG_TC2));
  /* Check the corectness of written data */
  TransferStatus = Buffercmp(SPI1_Buffer_Rx, SPI2_Buffer_Tx, BufferSize);
     are equal */
     are different */
  while (1)
* Input          : None
* Output         : None
* Return         : None
  RCC_DeInit();
  /* Enable HSE */
    /* HCLK = SYSCLK */
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
  /* DMA clock enable */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA, ENABLE);
* Input          : None
* Output         : None
* Return         : None
  /* Configure SPI1 pins: NSS, SCK, MISO and MOSI ----------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
  /* Configure SPI2 pins: NSS, SCK, MISO and MOSI ----------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
* Input          : None
* Output         : None
* Return         : None
#ifdef  VECT_TAB_RAM
#endif
* Output         : None
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
#ifdef  DEBUG
* Output         : None
* Return         : None
  /* Infinite loop */
  while (1)
#endif
* Version            : V1.0
* Date               : 10/08/2007
#include "spi_flash.h"
#define  FLASH_WriteAddress     0x700000
#define  FLASH_ReadAddress      FLASH_WriteAddress
#define  FLASH_SectorToErase    FLASH_WriteAddress
#define  M25P64_FLASH_ID        0x202017
#define  BufferSize (countof(Tx_Buffer)-1)
#define countof(a) (sizeof(a) / sizeof(*(a)))
u8 Tx_Buffer[] = "STM32F10x SPI Firmware Library Example: communication with an M25P64 SPI FLASH";
u8 i, Rx_Buffer[BufferSize];
volatile TestStatus TransferStatus1 = FAILED, TransferStatus2 = PASSED;
vu32 FLASH_ID = 0;
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* Initialize the SPI FLASH driver -----------------------------------------*/
  SPI_FLASH_Init();
  /* Get SPI Flash ID */
  FLASH_ID = SPI_FLASH_ReadID();
  /* Check the SPI Flash ID */
  if(FLASH_ID == M25P64_FLASH_ID)
    /* OK: Turn on led connected to PC6 */
    GPIO_WriteBit(GPIOC, GPIO_Pin_6, Bit_SET);
  else
    /* Error: Turn on led connected to PC7 */
    GPIO_WriteBit(GPIOC, GPIO_Pin_7, Bit_SET);
  /* Perform a write in the Flash followed by a read of the written data -----*/
  /* Erase SPI FLASH Sector to write on */
  SPI_FLASH_SectorErase(FLASH_SectorToErase);
  /* Write Tx_Buffer data to SPI FLASH memory */
  SPI_FLASH_BufferWrite(Tx_Buffer, FLASH_WriteAddress, BufferSize);
  /* Read data from SPI FLASH memory */
  SPI_FLASH_BufferRead(Rx_Buffer, FLASH_ReadAddress, BufferSize);
  TransferStatus1 = Buffercmp(Tx_Buffer, Rx_Buffer, BufferSize);
  /* TransferStatus1 = PASSED, if the transmitted and received data by SPI1
     are the same */
  /* TransferStatus1 = FAILED, if the transmitted and received data by SPI1
     are different */
  /* Perform an erase in the Flash followed by a read of the written data ----*/
  /* Check the corectness of erasing operation dada */
  for(i=0; i<BufferSize; i++)
    if(Rx_Buffer[i] != 0xFF)
  /* TransferStatus2 = PASSED, if the specified sector part is erased */
  /* TransferStatus2 = FAILED, if the specified sector part is not well erased  */
  while (1)
* Input          : None
* Output         : None
* Return         : None
  RCC_DeInit();
  /* Enable HSE */
    /* HCLK = SYSCLK */
    /* PCLK2 = HCLK */
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
  /* Enable GPIOC clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
* Input          : None
* Output         : None
* Return         : None
  /* Configure PC6 and PC7 as Output push-pull -------------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
#ifdef  VECT_TAB_RAM
#endif
* Output         : None
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
#ifdef  DEBUG
* Output         : None
* Return         : None
  /* Infinite loop */
  while (1)
#endif
