我这里的HP3070有一个多月没有开机用了,现在需要用它,今天一开机启动HP-Unix系统就出现如附图所示的错误信息,无法启动,哪位大哥知道这是怎么回事啊,怎么样才能解决这个问题啊?以下是一些错误信息:
Attempting to boot Alternate Path...
Attempted boot failed,continuing search
Attempted to boot first valid device on builtin FWSCSI ...
Attempted to boot first valid device on GSC1 ...
Module not found,continuing search
Attempted to boot first valid device on PCI1 ...
Attempted to boot first valid device on GSC2 ...
Attempted to boot first valid device on PCI2 ...
Attempted to boot device 6 on builtin SESCSI ...
Attempting to boot first valid server on LAN...
Search terminated.
Boot terminated.
--------Main Menu--------
Command Description
BOot [PRI|ALT|] Boot from specified path
PRth [PRI|ALT|CON|KEY] [path>] Display or modify a path
SERrch [DIsplay|IPL] [] Search for boot devices
COnfiguration [] Access Configuration menu/commands
INformation [] Access Information menu/commands
SERvice [] Access Service menu/commands
DIsplay Redisplay the current menu
HElp [
