This is the fourth version of the book and this version now not only provides
VHDL language coverage but design methodology information as well. This
version will guide the reader through the process of creating a VHDL
design, simulating the design, synthesizing the design, placing and routing
the design, using VITAL simulation to verify the final result, and a new
technique called At-Speed debugging that provides extremely fast design
verification. The design example in this version has been updated to reflect
the new focus on the design methodology.
This book was written to help hardware design engineers learn how to
write good VHDL design descriptions. The goal is to provide enough VHDL
and design methodology information to enable a designer to quickly write
good VHDL designs and be able to verify the results. It will also attempt
to bring the designer with little or no knowledge of VHDL, to the level of
writing complex VHDL descriptions. It is not intended to show every possible
construct of VHDL in every possible use, but rather to show the designer
how to write concise, efficient, and correct VHDL descriptions of
hardware designs
