标题: 急问个问题(关于移植uClinux的)!!!!! [打印本页]
作者: fodywang    时间: 2005-11-12 15:46     标题: 急问个问题(关于移植uClinux的)!!!!!
裁剪好内核,编译的时候报错,哪位大侠帮忙看看,到底什么原因?没辙了,不太懂这个,sigh
Kind Status riority Description Resource In Folder Location
Warning   signed size_t format, size_t arg (arg 2)[/cygdrive/f/niosIIIDEforinstall/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/fs/aio.c] kernel_1c6  line 661
Warning   size_t format, unsigned int arg (arg 6)[/cygdrive/f/niosIIIDEforinstall/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/base/dmapool.c] kernel_1c6  line 73
Warning   unused variable `dentry'[/cygdrive/f/niosIIIDEforinstall/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/fs/nfs/write.c] kernel_1c6  line 748
Warning   unused variable `fhp'[/cygdrive/f/niosIIIDEforinstall/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/fs/lockd/svcsubs.c] kernel_1c6  line 58
Warning   unused variable `inode'[/cygdrive/f/niosIIIDEforinstall/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/fs/lockd/svcsubs.c] kernel_1c6  line 127
Warning   unused variable `task'[/cygdrive/f/niosIIIDEforinstall/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/fs/nfs/write.c] kernel_1c6  line 864
Error   *** [_all] Error 2 kernel_1c6
Error   *** [drivers/ide/ide.o] Error 1 kernel_1c6
Error   *** [drivers/ide] Error 2 kernel_1c6
Error   *** [drivers] Error 2 kernel_1c6
Error   error: `na_ide_ide_irq' undeclared (first usemake: Leaving directory `/cygdrive/f/niosIIIDEforinstall/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'[/cygdrive/f/niosIIIDEforinstall/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c] kernel_1c6  line 313
Error   error: `na_ide_ide' undeclared (first use in this function)[/cygdrive/f/niosIIIDEforinstall/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c] kernel_1c6  line 262
Error   error: (Each undeclared identifier is reported only once[/cygdrive/f/niosIIIDEforinstall/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c] kernel_1c6  line 262
注:这里的/f/niosIIIDEforinstall是 nios2 devkit的安装目录
作者: kzw    时间: 2005-11-12 22:29
你具体到那些行看看吧,这个可能使你自己裁剪或者环境装的有问题,报的都是内核的错误。
作者: fodywang    时间: 2005-11-13 12:41
to kzw: 谢谢,我再瞧瞧吧,不行就重装环境试试[em01]
作者: kzw    时间: 2005-11-13 15:19
恩,估计只能这样了。
作者: bjxinxi    时间: 2005-11-14 21:15
Linux、GUI在SOPC系统NIOS上的移植开发培训
http://159.226.40.150/akaeweb/class/classdetail/nios.php
国内内容最详细、最深入的SOPC与Linux培训机构,将SOPC的灵活性和Linux的强大功能结合起来开发嵌入式系统
应用。内容包括FPGA、VHDL设计技巧、NIOS自定义指令系统的设计、外设IP Core的设计;包括DMA、中断、多
CPU系统、CF卡、网卡的程序设计实例;包括嵌入式操作系统UC/OS、Linux的移植和应用,尤其是Linux系统在自
定植SOPC板上的移植;还包括GUI的移植,尤其是UC/GUI在NIOS系统上的移植源代码分析;包括电路板级系统的
设计,FPGA、FLASH、SDRAM、配置电路的设计等等;每一部分内容都有详细的实例分析。最后,结合完整的工程
实践项目:便携式振动频谱分析仪 分析并实际设计一个完整的SOPC项目的全过程。
