用VHDL语言描述双向端口如下:
library ieee;
use IEEE.STD_LOGIC_1164.ALL;
entity bidirection_io is
port ( inner_port : inout std_logic_vector(7 downto 0);
out_en : in std_logic;
outer_port : inout std_logic_vector(7 downto 0) );
end bidirection_io;
architecture behavioral of bidirection_io is
begin
outer_port<=inner_port when out_en='1' else (OTHERS=>'Z');
inner_port<=outer_port when out_en='0' else (OTHERS=>'Z');
end behavioral;
initial
begin
out_en_tb=0;
inner_port_tb_reg=0;
outer_port_tb_reg=0;
i=0;
repeat(20)
begin
#50
i=$random;
out_en_tb=i[0]; //randomize out_en_tb
inner_port_tb_reg=$random; //randomize data
outer_port_tb_reg=$random;
end
end
//**** drive the ports connecting to bidirction_io
assign inner_port_tb_wire=(out_en_tb==1)?inner_port_tb_reg:8'hzz;
assign outer_port_tb_wire=(out_en_tb==0)?outer_port_tb_reg:8'hzz;
//最不懂的就是这儿了,估计也是最重要的地儿
//instatiate the bidirction_io module
bidirection_io bidirection_io_inst(.inner_port(inner_port_tb_wire),
.out_en(out_en_tb),
.outer_port(outer_port_tb_wire));
//***** monitor ******
always@(out_en_tb,inner_port_tb_wire,outer_port_tb_wire)
begin
#1;
if(outer_port_tb_wire===inner_port_tb_wire)
begin
$display("\n **** time=%t ****",$time);
$display("OK! out_en=%d",out_en_tb);
$display("OK! outer_port_tb_wire=%d,inner_port_tb_wire=%d",
outer_port_tb_wire,inner_port_tb_wire);
end
else
begin
$display("ERROR! out_en=%d",out_en_tb);
$display("ERROR! outer_port_tb_wire != inner_port_tb_wire" );
$display("ERROR! outer_port_tb_wire=%d, inner_port_tb_wire=%d",
end
end
endmodule
