小弟利用CodeWarrior对 Adtapt MC9S12E128 建立了一个简单的project:想实现利用输入开关来控制输出LEDs亮/灭的实验。我已经参照参考资料变了一点code如下.有一些问题。输入开关一直不工作。其高手指点。谢过了!
#include "Cpu.h"
#include "OnGreen.h"
#include "ONYellow.h"
#include "OffGreen.h"
#include "OffYellow0.h"
#include "selectInput.h"
#include "TestOK.h"
#include "TInputs.h"
#include "Bit1.h"
/* Include shared modules, which are used for whole project */
#include "PE_Types.h"
#include "PE_Error.h"
#include "PE_Const.h"
#include "IO_Map.h"
byte Tinputs;
byte Uinputs;
bool select;
bool input;
void main(void)
/*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/
PE_low_level_init();
/*** End of Processor Expert internal initialization. ***/
/*Write your code here*/
OnGreen_SetBit(0); /*Port name: A*/
OnGreen_ClrBit(0); /*Port name: A*/
ONYellow_SetBit(0); /*Port name: B*/
ONYellow_ClrBit(0); /*Port name: B*/
OffYellow0_SetVal(); /*Port name: Q*/
OffYellow0_ClrVal(); /*Port name: Q*/
Tinputs = TInputs_GetVal(); /*Port name: T*/
select = SelectInput_GetVal();
TestOK_SetVal();
TestOK_ClrVal();
/*** Processor Expert end of main routine. DON'T MODIFY THIS CODE!!! ***/
for(;;);
/*** Processor Expert end of main routine. DON'T WRITE CODE BELOW!!! ***/
} /*** End of main routine. DO NOT MODIFY THIS TEXT!!! ***/
