标题: I cannot get the DSP to boot up properly in standalone mode [打印本页] 作者: zhz2112 时间: 2005-12-6 12:33 标题: I cannot get the DSP to boot up properly in standalone mode
: I cannot get the DSP to boot up properly > in standalone > mode, when disconnected from the PC. I use the C+ASM > stationery. The > startup code which copies variables from FLASH to > RAM at startup seems > to work properly. I program the DSP, disconnect the > demo board from > the JTAG programmer, power down, power up again. The > DSP rarely boots > up succesfully (this is very strange, it would be > more straightforward > if it *never* booted up...) 作者: powerwu 时间: 2005-12-6 14:19
我想你这段英文是从Yahoo的DSP News Group 看到的,如果你现在回到那个Group,你的问题已有人答了,是CodeWarrior Stationery 的 MC56F801x_init.asm 文件个bug.附件的文件是正确的. 所以用PE的Stationery产生Project 总是正确的http://bbs.chinaecnet.com/uploadImages/MC56F801x_init.zip
