标题: XILINX在下载遇到问题,请指教。 [打印本页]
作者: hya    时间: 2005-12-28 09:43     标题: XILINX在下载遇到问题,请指教。
在下载时候,我遇到的问题:isp3 iMPACT - "ERROR: iMPACT:583 - '2' The IDCODE read from the device does not match the IDCODE in the BSDL file"
这是在XILINX网上看到的帮助,小弟还是看不懂。那位高人指导下。谢谢。
1. Older CoolRunner devices may have a Philips IDCODE instead of a Xilinx IDCODE. (Xilinx acquired the CoolRunner line from Philips.) If iMPACT reports this error message for a CoolRunner device, a slight modification to the IDCODE register in the BSDL file is required. In the IDCODE Register, "X" out the Manufacturer bits of the IDCODE:
"0000" & -- Version
"0100100010001011" & -- Part Number
"XXXXXXXXXXX" & -- Manufacturer
"1"; -- Mandatory
NOTES:
a. The part number in this example may differ from the part number in the BSDL file for your device.
b. The BSDL file that requires this modification is the "generic" xcr*xl.bsd file located at $xilinx\xpla3\data. iMPACT does not use the package-specific BSDL file.
c. Restart iMPACT to ensure that the modified BSDL file is loaded.
For example:
Device..................................Generic BSDL file
XCR3256XL_CS280 ............xcr3256xl.bsd
XCR3256XL_FT256 .............xcr3256xl.bsd
XCR3128XL_TQ144..............xcr3128xl.bsd
作者: lianzishu    时间: 2006-4-30 13:56
我也遇到这样的问题 清高手指点
谢谢
作者: stone133    时间: 2006-4-30 17:45
某些老型号或者莫某些型号是由别的厂家代为生产的,里面的IDCODE打上的是这些厂家的号码,所以impact不认,也就是和BSDL文件内保存的信息不一致;
去你的安装目录找到相应的BSDL文件,按照说明改动一下,你看到xilinx网站上看到的帮助不应该只有你贴出来的那些,下面还有,你仔细看看
