library IEEE;-- declare the library
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
entity FIR_filter is
port(rst:instd_logic;
clk:instd_logic;
coef_ld:instd_logic;
start:instd_logic;
o_enable:instd_logic;
bypass:instd_logic;
Xn_in:in std_logic_vector(3 downto 0);
Yn_in:instd_logic_vector(15 downto 0);
Xn_oututstd_logic_vector(3 downto 0);
Yn_oututstd_logic_vector(15 downto 0)
end FIR_filter;
architecture BEH of FIR_filter is
constant K:integer := 4;-- circuit has four stages
-- use type and subtype to define the complex signals
subtype bit4 isstd_logic_vector(3 downto 0);
subtype bit8 isstd_logic_vector(7 downto 0);
subtype bit16 isstd_logic_vector(15 downto 0);
type klx4isarray (K downto 0) of bit4;
type kx8isarray (K-1 downto 0) of bit8;
type klx8is array (K downto 0) of bit8;
type kx16isarray (K-1 downto 0) of bit16;
type klx16isarray (K downto 0) of bit16;
-- define signal in type of arrays
signalREG1, REG2, COEF: klx4;
signalMULT8: kx8;
signalMULT16: kx16;
signalSUM: klx16;
signalXn_tmp: bit4;
signalYn_tmp: bit16;
begin
-- initialize the first stage
of FIR circuit
REG2(K)<= Xn_in when (start='1')
else (REG2(K)'range => '0');
REG1(K) <= (REG1(K)'range => '0');
SUM(K) <= Yn_in;
COEF(K) <= Xn_in;
-- start the computation, use generate to obtain the
-- multiple stages
gen8:for j in K-1 downto 0 generate
stages:process (rst, clk)
begin
if (rst='0') then
REG1(j) <= (REG1(j)'range => '0');
REG2(j) <= (REG2(j)'range => '0');
COEF(j) <= (COEF(j)'range => '0');
MULT16(j) <= (MULT16(j)'range => '0');
SUM(j) <= (SUM(j)'range => '0');
elsif (clk'event and clk ='1') then
REG1(j) <= REG2(j+1);
REG2(j) <= REG1(j);
if (coef_ld = '1') then
COEF(j) <= COEF(j+1);
end if;
MULT8(j) <= signed(REG1(j))*signed(COEF(j));
MULT16(j)(7 downto 0) <= MULT8(j);
if (MULT8(j)(7)='0') then
MULT16(j)(15 downto <= "00000000";
else
MULT16(j)(15 downto <= "11111111";
end if;
SUM(j) <= signed(MULT16(j))+signed(SUM(j+1));
end if;
end process;
end generate;
-- control the outputs by concurrent statements
Xn_tmp <= Xn_inwhen bypass = '1' else
REG2(0) when coef_ld = '0' else
COEF(0);
Yn_tmp <= Yn_inwhen bypass = '1' else
SUM(0);
Xn_out <= Xn_tmpwhen o_enable = '0' else
(Xn_out'range => 'Z');
Yn_out <= Yn_tmpwhen o_enable = '0' else
(Yn_out'range => 'Z');
end BEH;
