//All behavioral statements must be inside an initial or always block
initial
begin
x = 0; y = 1; z = 1; //Scalar assignments
count = 0; //Assignment to integer variables
reg_a = 16'b0; reg_b = reg_a; //initialize vectors
reg_a[2] = #15 1; //Bit select assignment with delay
reg_b[15:13] = #10 {x, y, z};//Assign result of concatenation to
// part select of a vector
count = count + 1; //Assignment to an integer (increment)
end
initial
$monitor($time,
" x = %b, y = %b, z = %b, count = %0d, reg_a = %x, reg_b = %x",
x, y, z, count, reg_a, reg_b);
//Example 2: Synchronize two register values at every positive edge of
//clock
reg clock;
reg x, y;
initial
begin
clock = 1'b0;
x = 1'b0;
y = 1'b0;
#100000 $finish;
end
always #5 clock = ~clock;
always #11 y = ~y;
initial
forever @(posedge clock) x = y;
endmodule作者: silverwolf 时间: 2003-7-10 10:11
6.fulladd
/ Define a 4-bit full adder
module fulladd4(sum, c_out, a, b, c_in);
// I/O port declarations
output [3:0] sum;
output c_out;
input[3:0] a, b;
input c_in;
// Specify the function of a full adder
assign #2 {c_out, sum} = a + b + c_in;
endmodule
// Define the stimulus (top level module)
module stimulus;
// Set up variables
reg [3:0] A, B;
reg C_IN;
wire [3:0] SUM;
wire C_OUT;
// Instantiate the 4-bit full adder. call it FA1_4
fulladd4 FA1_4(SUM, C_OUT, A, B, C_IN);
// Setup the monitoring for the signal values
initial
begin
$monitor($time," A= %b, B=%b, C_IN= %b,, C_OUT= %b, SUM= %b\n",
A, B, C_IN, C_OUT, SUM);
end作者: silverwolf 时间: 2003-7-10 10:12
7.func2
//Define a module which contains the function shift
module shifter;
//Left/right shifter
`define LEFT_SHIFT 1'b0
`define RIGHT_SHIFT 1'b1
reg [31:0] addr, left_addr, right_addr;
reg control;
initial
begin
$monitor("%0d left= %h right = %h addr = %h",
$time, left_addr, right_addr, addr);
#1 addr = 32'h3456_789a;
#10 addr = 32'hc4c6_78ff;
#10 addr = 32'hff56_ff9a;
#10 addr = 32'h3faa_aaaa;
end
//Compute the right and left shifted values whenever
//a new address value appears
always @(addr)
begin
//call the function defined below to do left and right shift.
left_addr = shift(addr, `LEFT_SHIFT);
right_addr = shift(addr, `RIGHT_SHIFT);
end
//define shift function. The output is a 32-bit value.
function [31:0] shift;
input [31:0] address;
input control;
begin
//set the output value appropriately based on a control signal.
shift = (control == `LEFT_SHIFT) ?(address << 1) : (address >> 1);
end
endfunction
endmodule作者: silverwolf 时间: 2003-7-10 10:13
8.imp_del
module implicit_delay (out, in1, in2);
output out;
input in1, in2;
wire #10 out = in1 & in2; // Delay in a continuous assign
initial
m = 1'b0; //single statement; does not need to be grouped
initial
begin
#5 a = 1'b1; //multiple statements; need to be grouped
#25 b = 1'b0;
end
initial
begin
#10 x = 1'b0;
#25 y = 1'b1;
end
initial
#50 $finish;
endmodule作者: silverwolf 时间: 2003-7-10 10:55
10.momory
module test;
reg [7:0] memory[0:7]; //declare an 8 bit memory with 8 locations
integer i;
initial
begin
//read memory file. address locations given in memory
$readmemb("init.dat", memory);
//display contents of initialized memory
for(i=0; i < 8; i = i + 1)
$display("Memory [%0d] = %b", i, memory);
end
endmodule作者: silverwolf 时间: 2003-7-10 10:57
11.mux1
/ 4-to-1 multiplexer. Port list is taken exactly from
// the I/O diagram.
module mux4_to_1 (out, i0, i1, i2, i3, s1, s0);
// Port declarations from the I/O diagram
output out;
input i0, i1, i2, i3;
input s1, s0;
13.mux4
// 4-to-1 multiplexer. Port list is taken exactly from
// the I/O diagram.
output out;
input s1, s0;
//output declared as register
reg out;
//recompute the signal out if any input signal changes.
//All input signals that cause a recomputation of out to
//occur must go into the always @(...)
always @(s1 or s0 or i0 or i1 or i2 or i3)
begin
case ({s1, s0})
2'b00: out = i0;
2'b01: out = i1;
2'b10: out = i2;
2'b11: out = i3;
default: out = 1'bx;
endcase
end
endmodule
// Define the stimulus module (no ports)
module stimulus;
// Declare variables to be connected
// to inputs
reg IN0, IN1, IN2, IN3;
reg S1, S0;
always @(posedge clock)
begin
if(data_start) //data start signal is true
begin
i = 0;
repeat(cycles) //Store data at the posedge of next 8 clock
//cycles
begin
@(posedge clock) buffer = data; //waits till next
// posedge to latch data
i = i + 1;
end
end
end
endmodule作者: silverwolf 时间: 2003-7-10 11:00
15.sig-ctrl
`define TRUE 1'b1
`define FALSE 1'b0
`define RED 2'd0
`define YELLOW 2'd1
`define GREEN 2'd2
//State definition HWY CNTRY
`define S0 3'd0 //GREEN RED
`define S1 3'd1 //YELLOW RED
`define S2 3'd2 //RED RED
`define S3 3'd3 //RED GREEN
`define S4 3'd4 //RED YELLOW
//Delays
`define Y2RDELAY 3 //Yellow to red delay
`define R2GDELAY 2 //Red to Green Delay
module sig_control
(hwy, cntry, X, clock, clear);
//I/O ports
output [1:0] hwy, cntry;
//2 bit output for 3 states of signal
//GREEN, YELLOW, RED;
reg [1:0] hwy, cntry;
//declare output signals are registers
input X;
//if TRUE, indicates that there is car on
//the country road, otherwise FALSE
input clock, clear;
//Internal state variables
reg [2:0] state;
reg [2:0] next_state;
//Signal controller starts in S0 state
initial
begin
state = `S0;
next_state = `S0;
hwy = `GREEN;
cntry = `RED;
end
//state changes only at positive edge of clock
state = next_state;
//Compute values of main signal and country signal
always @(state)
begin
case(state)
`S0: begin
hwy = `GREEN;
cntry = `RED;
end
`S1: begin
hwy = `YELLOW;
cntry = `RED;
end
`S2: begin
hwy = `RED;
cntry = `RED;
end
`S3: begin
hwy = `RED;
cntry = `GREEN;
end
`S4: begin
hwy = `RED;
cntry = `YELLOW;
end
endcase
end
//State machine using case statements
always @(state or clear or X)
begin
if(clear)
next_state = `S0;
else
case (state)
`S0: if( X)
next_state = `S1;
else
next_state = `S0;
`S1: begin //delay some positive edges of clock
repeat(`Y2RDELAY) @(posedge clock) ;
next_state = `S2;
end
`S2: begin //delay some positive edges of clock
repeat(`R2GDELAY) @(posedge clock)
next_state = `S3;
end
`S3: if( X)
next_state = `S3;
else
next_state = `S4;
`S4: begin //delay some positive edges of clock
next_state = `S0;
end
default: next_state = `S0;
endcase
end
endmodule
//Stimulus Module
module stimulus;
wire [1:0] MAIN_SIG, CNTRY_SIG;
reg CAR_ON_CNTRY_RD;
//the country road
reg CLOCK, CLEAR;
//Instantiate signal controller
sig_control SC(MAIN_SIG, CNTRY_SIG, CAR_ON_CNTRY_RD, CLOCK, CLEAR);
//Setup monitor
initial
$monitor($time, " Main Sig = %b Country Sig = %b Car_on_cntry = %b",
MAIN_SIG, CNTRY_SIG, CAR_ON_CNTRY_RD);
16.task
//Define a module called operation which contains the task bitwise_oper
module operation;
parameter delay = 10;
reg [15:0] A, B;
reg [15:0] AB_AND, AB_OR, AB_XOR;
initial
$monitor( "%0d AB_AND = %b, AB_OR = %b, AB_XOR = %b, A = %b, B = %b",
$time, AB_AND, AB_OR, AB_XOR, A, B);
initial
begin
#1 A = 16'b1111_0000_1010_0111;
B = 16'b1010_0101_1000_1100;
end
always @(A or B) //whenever A or B changes in value
begin
//invoke the task bitwise_oper. provide 2 input arguments A, B
//Expect 3 output arguments AB_AND, AB_OR, AB_XOR
//The arguments must be specified in the same order as they
//appear in the task declaration.
bitwise_oper(AB_AND, AB_OR, AB_XOR, A, B);
end
//define task bitwise_oper
task bitwise_oper;
output [15:0] ab_and, ab_or, ab_xor; //outputs from the task
input [15:0] a, b; //inputs to the task
begin
#delay ab_and = a & b;
ab_or = a | b;
ab_xor = a ^ b;
end
endtask
endmodule作者: silverwolf 时间: 2003-7-10 11:01
17.while
module count;
//Illustration 1: Increment count from 0 to 127.
//Exit at count 128. Display the count variable.
integer count;
initial
begin
count = 0;
while (count < 128) //Execute loop till count is 127.
//exit at count 128
begin
$display("Count = %d", count);
count = count + 1;
end
end
