Sometimes I need to generate a clock at a lower frequency than the main clock driving the FPGA. If the ratio of the frequencies is a power of 2, the logic is easy. If the ratio is an integer N, then a divide-by-N counter is only a little harder. But if the ratio isn't an integer, a little (and I mean a little) math is required.
Note that the new clock will have lots of jitter: there's no escaping that. But it will have no drift, and for some applications that's what counts.
If you have a clock A at frequency a, and want to make a clock B at some lower frequency b (that is, b < a), then something like:
d = 0; |
but comparison against zero is easier, so subtract 1 from d:
d = 0; |
want an integer representation, so multiply everything by a:
d = 0; |
For example. I just bought a bargain batch of 14.1523MHz oscillators from BG but I need to generate a 24Hz clock.
So a=14152300 and b=24:
d = 0; |
For a hardware implementation I need to know how many bits are needed for d: here it's 24 bits to hold the largest value (-14152300) plus one more bit for the sign. In VHDL this looks like:
signal d, dInc, dN : std_logic_vector(24 downto 0); |
