我现在使用的是经过三次升级的Protel DXP 即已经与 Altium Designer 没有什么区别了。使用中,在编译时遇到了以下的几个提示,不知道改怎么处理? 请高手指点。
1.[Warning] main mcu of final3.SCHDOC Compiler Adding items to hidden net GND
2.[Warning] main mcu of final3.SCHDOC Compiler Adding items to hidden net VCC
3.[Warning] top of final3.SCHDOC Compiler Same parameter contains different values top of final3.SCHDOC Undefined and
4.[Warning] main mcu of final3.SCHDOC Compiler NetU2_1 contains IO Pin and Unspecified Port objects (Port MAX186 CS)
5.[Warning] anolog input of final3.SCHDOC Compiler NetU5_10 contains Input Pin and Unspecified Port objects (Port SHDN)
6.[Warning] top of final3.SCHDOC Compiler Same parameter contains different values top of final3.SCHDOC and 1.0
7.[Warning] top of final3.SCHDOC Compiler Nets Wire JTAG_TCK has multiple names (Net Label JTAG_TCK,Sheet Entry external expand of final3-N24(Passive))
8.[Warning] anolog input of final3.SCHDOC Compiler Net VOLTAGE 4 has no driving source (Pin R17-1,Pin R20-1,Pin U3-9,Pin U5-5)
以上就是我遇到的集中编译错误。不知道这些错误是否会导致PCB网络表的错误,所以,在交付厂家生产PCB板之前,望各位高手不吝赐教。
再次不胜感激!!!
Maywolf
