The PLX PCI9054 is a 32-bit, 33-MHz PCI Bus general purpose PCI Master device. It acts as a
PCI bridge between the PCI bus and the user circuits. The PLX PCI9054 handles all of the PCI
signaling and software interfacing and translates the PCI bus cycles to a simple control, address,
data general interface for easy connectivity of memory and I/O devices.
It has two interfaces for this purpose which are designated as following:
− the PCI bus interface
− the Local bus interface
