[url=]L1822: Symbol <Symbol Name> in file <File Name> is undefined[/url][DISABLE, INFORMATION, WARNING, ERROR]
[url=]Description[/url]The specified symbol is referenced in the file specified, but is not defined anywhere in the application.
[url=]Tips[/url]Check if there is no object file missing in the NAMES block and if you are using the correct binary file. Check if your paths are defined correctly. The binary files must be located in one of the paths enumerated in the environment variable OBJPATH or GENPATH or in the working directory
我看了论坛上关于L1822错误的帖子,回头设置All float and double variables are 32bit/IEEE32.但是还是提示错误L1822,请问为什么作者: dsz0518 时间: 2012-8-4 10:31
