标题: “Putting Analog on the Bus”是否意指对Analog Signal进行A/D转换? [打印本页] 作者: ljp 时间: 2003-8-8 14:15 标题: “Putting Analog on the Bus”是否意指对Analog Signal进行A/D转换?
“Putting Analog on the Bus”是否意指对Analog Signal进行A/D转换?作者: samire 时间: 2003-8-8 14:15
Putting Analog on the bus" is a concept proposed by Xicor, which is our goal. Using XDCP, you can program the analog function block usign SPI, I2C system bus... which is "putting analog on the bus"
