标题: Whether is the resolution of a XDCP higher with increasing the number of the [打印本页] 作者: qin 时间: 2003-8-12 15:15
I may not totally understand your meaning. However, it should be作者: hstaii@163.net 时间: 2003-8-12 15:15 标题: Whether is the resolution of a XDCP higher with increasing the number of the
Whether is the resolution of a XDCP higher with increasing the number of the tap?
