我再程序里先写满1片24C02,再把里面的内容读到片内RAM中.
虽然能正确写进去了,但是读的时候总是读出256个0xFF
请大家帮忙看看什么问题 !!!!!!!
void I2C0_init(void) {
unsigned char i;
re_send_sladd=0;//it's used in the begin of the read to send the slave address again acording the I2C protocol
i2c_step=0;//use this semaphore to control the cycle of read and write
new_inner_page=1;//1 means a new page is begin,0 means the old page is not finished
i2c_page_counter=0;//24c02 has 32 pages with 8 byte per page
byte_write_conter=0;
I2C_frequency_define=0xBF;//use the lowest clock in debug
I2C_control_address_length=0;//use 7bit addressing
I2C_start;
i=I2C_data;//dummy read from IBDR register
void I2C0_start(unsigned char mode_select,unsigned char add_24c02,unsigned char direc_control){
while((I2C_status&0x20)>>5==1);//wait for the bus idle
I2C_control|=(0x41|mode_select);//interrupt enable,master,transmit,acknowledge if need
I2C_data=add_24c02|direc_control;//slave address and write to slave
while((I2C_status&0x20)>>5!=1);//ensure the bus is engrossed by it
void main(void) {
SetupXGATE();
I2C0_init();
interrupt_init();
EnableInterrupts;
for(;;) {
switch(i2c_step) {
case 0:
i2c_step=1;
I2C0_start(master_write,i2c_chip_add,write);//generate START,send slave address;master write
break;
case 1:
break;
case 2:
i2c_step=1;
if(re_send_sladd==0){ //the first time to send 24C02's address
re_send_sladd=1;//make the following ISR switch to "case master_r_select_add"
else if(re_send_sladd==2){
re_send_sladd=0;
I2C_control&=0xEF;//clear the Tx/Rx bit to select receive mode
Repeat_start;//generate repeat start
I2C_data=i2c_chip_add|read;
else{;}
break;
default:{;}
}//end of switch
}//end of the loop
}//end of main
