library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity adder is
port(cin:in std_logic;
a,b:in std_logic_vector(3 downto 0);
sut std_logic_vector(3 downto 0);
cout std_logic);
end adder;
architecture behav of adder is
signal temp:std_logic_vector(4 downto 0);
begin
process(a,b,cin)
begin
temp<=('0'&a)+b+cin;
if(temp(3 downto 0)>9 or (temp(4)='1')then
s<=temp(3 downto 0)+6;
co<='1';
else
s<=temp(3 downto 0);
co<='0';
end if;
end process;
end behav;
unexpected end-of-file
-try using the Text Editor's Syntax Coloring command to find the missing
delimiter or keyword
