标题: Altium_Designer_官方培训教材(合集)_全 03 [打印本页]
作者: samwalton    时间: 2013-1-6 15:53     标题: Altium_Designer_官方培训教材(合集)_全 03
Module 1: Getting Started With Altium Designer
1.1 Introduction to Altium Designer.........................................................................................1-1
1.2 The Altium Designer environment.....................................................................................1-2
1.3 Document Editor Overview................................................................................................1-6
1.4 Working with projects and documents............................................................................1-10
Module 2: Help and DXP system menu
2.1 Using the Help system.......................................................................................................2-1
2.2 Using the Altium website...................................................................................................2-3
2.3 DXP System menu...........................................................................................................2-10
Module 3: Schematic Editor Basics
3.1 Schematic Editor basics....................................................................................................3-1
3.2 Schematic graphical objects..............................................................................................3-4
3.3 Schematic electrical objects..............................................................................................3-9
Module 4: Schematic Capture
4.1 Introduction to Schematic Capture....................................................................................4-1
4.2 The Schematic Editor workspace......................................................................................4-2
4.3 Libraries and components.................................................................................................4-9
4.4 Placing and wiring............................................................................................................4-17
Module 5: Multi-Sheet Design
5.1 Multi-Sheet Design.............................................................................................................5-1
Module 6: Building the Project
6.1 Assigning designators........................................................................................................6-1
6.2 Compiling and verifying the project...................................................................................6-5
Module 7: Setting Up for Transfer to PCB and Importing Data
7.1 Setting Up for Transfer to PCB..........................................................................................7-1
Module 8: PCB Editor Basics
8.1 PCB Editor Basics..............................................................................................................8-1
8.2 PCB design objects............................................................................................................8-4
Module 9: Setting up the PCB
9.1 Setting up the PCB.............................................................................................................9-1
9.2 Creating a new PCB..........................................................................................................9-6
9.3 Setting up the PCB layers................................................................................................9-10
Module 10: Global Editing
10.1 Editing Multiple Text Objects...........................................................................................10-1
10.2 The Data Editing System.................................................................................................10-4
Module 11: PCB Design Flow, Transferring a Design and Navigation
11.1 PCB design process........................................................................................................11-1
11.2 Transferring design information to the PCB......................................................................11-3
11.3 Using the PCB Panel.......................................................................................................11-7
11.4 Project Navigation and Cross Probing..........................................................................11-16
Module 12: Design Rules
12.1 Design rules and design rule checking...........................................................................12-1
Module 13: Classes and Rooms
13.1 Object classes..................................................................................................................13-1
13.2 Rooms.............................................................................................................................13-3
Module 14: Placement and Re-annotation
14.1 Component Placement tools...........................................................................................14-1
14.2 Re-Annotation and back annotate...................................................................................14-3
Module 15: Schematic Library Editor
15.1 Introduction to Library Editing..........................................................................................15-1
15.2 Schematic Library Editor..................................................................................................15-2
Module 16: PCB Library Editor
16.1 PCB Library Editor...........................................................................................................16-1
16.2 3D dimensional component detail.................................................................................16-14
Module 17: Linking Models, Parameters, Library Package and Updates
17.1 Adding Model and Parameter Detail to a Component..................................................17-1
17.2 Component Auditing........................................................................................................17-8
17.3 3D PCB Components....................................................................................................17-14
17.4 Library Package types...................................................................................................17-18
17.5 Library Reports...............................................................................................................17-20
Module 18: Routing and Polygons
18.1 Routing............................................................................................................................18-1
18.2 Testpoint System...........................................................................................................18-10
18.3 Adding and removing teardrops....................................................................................18-15
18.4 Automatic routing...........................................................................................................18-16
18.5 Polygons and the Polygon Manager.............................................................................18-19
Module 19: Output Generation and CAM File Editing
19.1 Bill of Materials.................................................................................................................19-1
19.2 Output Generation............................................................................................................19-8
19.3 CAM Editor.....................................................................................................................19-20
Module 20: Interfacing to 3D Mechanical CAD
20.1 Interfacing to 3D Mechanical CAD..................................................................................20-
附件: Altium_Designer_官方培训教材(合集)_全 03.rar (2013-1-6 15:53, 430.25 KB) / 下载次数 585
http://bbs.eccn.com/attachment.php?aid=29797&k=4d7da722b772ccbb8586536e267d1adc&t=1732300229&sid=o08DGq
