三轴加速度计测试代码
海洋狂吻
2013-12-21 20:40
三轴加速度计测试代码
#include "LSM303.h"
#include "usart.h"
#include "I2C.h"
#include <math.h> //Keil library
//************初始化L3G4200D的加速度*********************************
void LSM303A_Init( void )
I2C_WriteOneByte(I2C1,LSM303A_I2C_ADDR,LSM303A_CTRL_REG1, 0x37);
I2C_WriteOneByte(I2C1,LSM303A_I2C_ADDR,LSM303A_CTRL_REG4, 0x00);
//************初始化L3G4200D的磁感应*********************************
void LSM303M_Init( void )
I2C_WriteOneByte(I2C1,LSM303M_I2C_ADDR,LSM303M_CRB_REG, 0xa0);
I2C_WriteOneByte(I2C1,LSM303M_I2C_ADDR,LSM303M_MR_REG, 0x00);
//********读取磁感应数据************************************
void LAM303M_Raed(float *Data)
static unsigned char buffer[6]={0};
unsigned char f,i;
unsigned int Magn_Sensitivity_XY = 0, Magn_Sensitivity_Z = 0;
uint16_t cen=0;
I2C_Read(I2C1,LSM303M_I2C_ADDR,LSM303M_OUT_X_H,buffer,6);//|0x80
I2C_Read(I2C1,LSM303M_I2C_ADDR,LSM303M_CRB_REG,&f,1);
switch(f & 0xE0)
case LSM303DLHC_FS_1_3_GA:
Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_1_3Ga;
Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_1_3Ga;
break;
case LSM303DLHC_FS_1_9_GA:
Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_1_9Ga;
Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_1_9Ga;
break;
case LSM303DLHC_FS_2_5_GA:
Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_2_5Ga;
Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_2_5Ga;
break;
case LSM303DLHC_FS_4_0_GA:
Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_4Ga;
Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_4Ga;
break;
case LSM303DLHC_FS_4_7_GA:
Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_4_7Ga;
Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_4_7Ga;
break;
case LSM303DLHC_FS_5_6_GA:
Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_5_6Ga;
Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_5_6Ga;
break;
case LSM303DLHC_FS_8_1_GA:
Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_8_1Ga;
Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_8_1Ga;
break;
for(i=0; i<2; i++)
cen=(int16_t)(((int16_t)buffer[2*i] << 8) + buffer[2*i+1]) ;
Data[i]=(float)(cen)*1000/Magn_Sensitivity_XY;
cen=(int16_t)(((uint16_t)buffer[0] << 8) + buffer[1]);
Data[0]=(float)((int16_t)cen)*1000/Magn_Sensitivity_Z;
cen=(int16_t)(((uint16_t)buffer[2] << 8) + buffer[3]);
Data[2]=(float)((int16_t)cen)*1000/Magn_Sensitivity_Z;
cen=(int16_t)(((uint16_t)buffer[4] << 8) + buffer[5]);
Data[1]=(float)((int16_t)cen)*1000/Magn_Sensitivity_Z;
cen=Data[1];
Data[1]=Data[2];
Data[2]=cen;
//********读取加速度数据************************************
void LAM303A_Raed(float *Data)
static unsigned char buffer[6]={0}, ctrlx[2],i;
unsigned char cDivider;
signed short int pnRawData[3];
float LSM_Acc_Sensitivity=LSM_Acc_Sensitivity_2g;
int16_t cen;
I2C_Read(I2C1,LSM303A_I2C_ADDR,LSM303A_OUT_X_L|0x80,buffer,6);
I2C_Read(I2C1,LSM303A_I2C_ADDR,LSM303A_CTRL_REG4|0x80,ctrlx,2);
if(ctrlx[1]&0x40)
cDivider=64;
else
cDivider=16;
/* check in the control register4 the data alignment*/
if(!(ctrlx[0] & 0x40) || (ctrlx[1] & 0x40)) /* Little Endian Mode or FIFO mode */
for(i=0; i<3; i++)
cen=(int16_t)((uint16_t)buffer[2*i+1] << 8) + buffer[2*i];
pnRawData[i]=(int16_t)(cen)/cDivider;
else /* Big Endian Mode */
for(i=0; i<3; i++)
pnRawData[i]=((int16_t)((uint16_t)buffer[2*i] << 8) + buffer[2*i+1])/cDivider;
/* Read the register content */
I2C_Read(I2C1,LSM303A_I2C_ADDR,LSM303A_CTRL_REG4,ctrlx,2);
if(ctrlx[1]&0x40)
/* FIFO mode */
LSM_Acc_Sensitivity = 0.25;
else
/* normal mode */
/* switch the sensitivity value set in the CRTL4*/
switch(ctrlx[0] & 0x30)
case LSM303DLHC_FULLSCALE_2G:
LSM_Acc_Sensitivity = LSM_Acc_Sensitivity_2g;
break;
case LSM303DLHC_FULLSCALE_4G:
LSM_Acc_Sensitivity = LSM_Acc_Sensitivity_4g;
break;
case LSM303DLHC_FULLSCALE_8G:
LSM_Acc_Sensitivity = LSM_Acc_Sensitivity_8g;
break;
case LSM303DLHC_FULLSCALE_16G:
LSM_Acc_Sensitivity = LSM_Acc_Sensitivity_16g;
break;
/* Obtain the mg value for the three axis */
for(i=0; i<3; i++)
Data[i]=(float)pnRawData[i]*LSM_Acc_Sensitivity;
float Data_conversion(float *AccBuffer,float *MagBuffer)
unsigned char i;
float HeadingValue = 0.0f;
float fNormAcc,fSinRoll,fCosRoll,fSinPitch,fCosPitch = 0.0f, RollAng = 0.0f, PitchAng = 0.0f;
float fTiltedX,fTiltedY = 0.0f;
float fcosf=0;
for(i=0;i<3;i++)
AccBuffer[i] /= 100.0f;
fNormAcc = sqrt((AccBuffer[0]*AccBuffer[0])+(AccBuffer[1]*AccBuffer[1])+(AccBuffer[2]*AccBuffer[2]));
fSinRoll = AccBuffer[1]/fNormAcc;
fCosRoll = sqrt(1.0-(fSinRoll * fSinRoll));
fSinPitch = AccBuffer[0]/fNormAcc;
fCosPitch = sqrt(1.0-(fSinPitch * fSinPitch));
fTiltedX = MagBuffer[0]*fCosPitch + MagBuffer[2]*fSinPitch;
fTiltedY = MagBuffer[0]*fSinRoll*fSinPitch + MagBuffer[1]*fCosRoll - MagBuffer[2]*fSinRoll*fCosPitch;
fcosf=fTiltedX /sqrt(fTiltedX*fTiltedX+fTiltedY*fTiltedY);
if(fTiltedY>0)
HeadingValue = (float)(acos(fcosf)*180/PI);
else
HeadingValue =360-(float)(acos(fcosf)*180/PI);
//HeadingValue = (float) ((atan2f((float)fTiltedY,(float)fTiltedX))*180)/PI;
HeadingValue+=11;//地磁的北极和地球的北极相差11度左右。
if(HeadingValue>360)
HeadingValue=HeadingValue-360;
return HeadingValue ;
