标题: [求助] Flash Programmer Usage Problem [打印本页]
作者: altonchan 时间: 2006-12-4 14:23 标题: [求助] Flash Programmer Usage Problem
During running flash programmer:
#! /bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd C:/altera/kits/nios2_60/bin/eclipse/workspace/Project/DE2_Board_new/DE2_Board
/system/software/count_binary_0/Debug
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --base=0x0040D800 --end=0x40d807 --reset=0x40c000
--input=count_binary_0.elf --output=asmi.flash --boot=$SOPC_KIT_NIOS2/components
/altera_nios2/boot_loader_cfi.srec
# Programming flash with the project
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --sidp=0x0040D838 --id=2273877087 --t
imestamp=1165198630 --base=0x0040D800 asmi.flash
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x0040D838: No CFI table found at address 0x0040D80
verified
Leaving target processor paused
$SOPC_KIT_NIOS2/bin/elf2flash --base=0x00000000 --end=0x3fffff --reset=0x40c000
--input=count_binary_0.elf --output=cfi_flash_0.flash --boot=$SOPC_KIT_NIOS2/com
ponents/altera_nios2/boot_loader_cfi.srec
imestamp=1165198630 --base=0x00000000 cfi_flash_0.flash
Reading System ID at address 0x0040D838: verified
What's wrong of my system ? (Some words output in console is in red)
It seems the program terminated abnormally ...
Please help
作者: kzw 时间: 2006-12-4 18:33
it seams that you could not connect to the target.
can you download codes in console mode.
作者: altonchan 时间: 2006-12-5 09:22
It is the same in console mode .... fail
作者: kzw 时间: 2006-12-5 21:29
you use DE2??
作者: altonchan 时间: 2006-12-6 08:36
Yes, I am using DE2
作者: kzw 时间: 2006-12-6 22:43
you use the example of DE2, can success??
if failed, there is something wrong with your board.
Powered by Discuz! 7.0.0 |
