二进制,八进制,十进制,十六进制互相转化的C语言源代码2
海洋狂吻
2014-3-1 16:27
///////以下为: 八进制转换为二进制,十进制,十六进制.
void O_B(int a)
int i,j,k,s=0;
int result=0;
int p[30];
for(i=1;a!=0;i*=8)
{if(a%10>7)
s=1;
break;
else
result+=(a%10)*i;
a=a/10;
for(j=0;result!=0;j++)
p[j]=result%2;
result=result/2;
if(s==1)
printf("您的输入有误!请重新输入\n");
else
printf("\n转换后的数为:");
for(k=j-1;k>=0;k--)
printf("%d",p[k]);
printf("\n");
void O_D(int a)
int i,s=0;
int result=0;
for(i=1;a!=0;i*=8)
if(a%10>7)
s=1;
break;
else
result+=(a%10)*i;
a=a/10;
if(s==1)
else
printf("\n转换后的数为:%d\n",result);
void O_X(int a)
int i,j,k,s=0;
char p[30];
int result=0;
for(i=1;a!=0;i*=8)
if(a%10>7)
s=1;
break;
else
result+=(a%10)*i;
a=a/10;
p[j]=result%16;
result=result/16;
if(p[j]<10)
p[j]+=48;
else
switch(p[j])
case 10: p[j]='A';
break;
case 11: p[j]='B';
break;
case 12: p[j]='C';
break;
case 13: p[j]='D';
break;
case 14: p[j]='E';
break;
case 15: p[j]='F';
break;
if(s==1)
else
for(k=j-1;k>=0;k--)
printf("%c",p[k]);
printf("\n");
///////以下为: 十六进制转换为十进制,二进制,八进制.
void X_D(char a[],int k)
int i,j,s=0;
int result=0;
int b[50];
for(i=0;i<k;i++)
if(a
<='9'&&a
>='1')
{ b
=a
-48;
else
switch(a
case
'A': b
=10;
break;
case
'B': b
=11;
break;
case
'C': b
=12;
break;
case
'D': b
=13;
break;
case
'E': b
=14;
break;
case
'F': b
=15;
break;
case
'a': b
=10;
break;
case
'b': b
=11;
break;
case
'c': b
=12;
break;
case
'd': b
=13;
break;
case
'e': b
=14;
break;
case
'f': b
=15;
break;
default: s=1;
for(i=1,j=k-1;j>=0;j--,i*=16)
result+=b[j]*i;
if(s==1)
else
printf("\n转换后的数为:%d",result);
void X_B(char a[],int k)
int i,j,s=0;
int result=0;
int b[50];
int p[30];
for(i=0;i<k;i++)
if(a
<='9'&&a
>='1')
b
=a
-48;
else
switch(a
case
'A': b
=10;
break;
case
'B': b
=11;
break;
case
'C': b
=12;
break;
case
'D': b
=13;
break;
case
'E': b
=14;
break;
case
'F': b
=15;
break;
case
'a': b
=10;
break;
case
'b': b
=11;
break;
case
'c': b
=12;
break;
case
'd': b
=13;
break;
case
'e': b
=14;
break;
case
'f': b
=15;
break;
default: s=1;
for(j=k-1,i=1;j>=0;j--,i*=16)
result+=b[j]*i;
p[j]=result%2;
result=result/2;
if(s==1)
else
for(k=j-1;k>=0;k--)
printf("%d",p[k]);
printf("\n");
void X_O(char a[],int k)
int i,j,s=0;
int result=0;
int b[30];
int p[30];
for(i=0;i<k;i++)
if(a
<='9'&&a
>='1')
b
=a
-48;
else
switch(a
case
'A': b
=10;
break;
case
'B': b
=11;
break;
case
'C': b
=12;
break;
case
'D': b
=13;
break;
case
'E': b
=14;
break;
case
'F': b
=15;
break;
case
'a': b
=10;
break;
case
'b': b
=11;
break;
case
'c': b
=12;
break;
case
'd': b
=13;
break;
case
'e': b
=14;
break;
case
'f': b
=15;
break;
default: s=1;
result+=b[j]*i;
p[j]=result%8;
result=result/8;
if(s==1)
else
for(k=j-1;k>=0;k--)
printf("%d",p[k]);
printf("\n");
