Module
| Examples
| Realize Functions
ADC
| 01 ADC_Interrupt
| ADC Conversion in Interruption model
02 ADC_Polling
| ADC Conversion in Polling model
CAN
| 03 Can_Selftest
| Test Can_Selftest model
CRC
| 04 Crc_Demo
| Apply in CRC via LPC1788
DAC
| 05 Dac_Dma
| Send or Receive data via DAC and DMA converter
06 Dac_SineWave
| Generate sine wave via DAC
DMA
| 07 DMA_Flash2Ram
| Transmit data from flash to RAM to test GPDMA
EEPROM
| 08 EEprom_Demo
| EEPROM Work mechanism in LPC1788
GPIO
| 09 GPIO_Interrupt
| Test GPIO Interruption function
10 GPIO_LedBlinky
| Drive LED to test GPIO Interruption function
NVIC
| 11 Nvic_VectorTableRelocation
| Vector Table Relocation
EMC
| 12 NandFlash
| Test Expansion Nandflash chip
13 NorFlash
| Test Expansion Norflash chip
14 SRAM
| Test Expansion SRAM chip
15 SDRAM
| Test Expansion SDRAM chip
PWM
| 16 Pwm_SingleEdge
| Use PWM signal in Single Edge model
17 Pwm_DualEdge
| Generate PWM signal in Dual Edge model
18 Pwm_MatchInterrupt
| Use PWM match function in Interruption model
RTC
| 19 Rtc_Alarm
| Generate alarm interruption per 10 seconds
Systick
| 20 Systick_10msBase
| Configure system clock to generate interruption per 10 seconds.
TIMER
| 21 TIMER_MatchInterrupt
| Generate specific time
PWR
| 22 PWR_Sleep
| Make system to Sleep mode and awaken by external interruption
23 PWR_DeepSleep
| Make system to Deep sleep mode and awaken by external interruption
EMAC
| 24 Emac_EasyWeb
| Ethernet port test,realize a simple web apply.
LCD
| 25 Lcd_LQ043T3DX0A
| Test LCD,Display specific picture
26 Lcd_touchscreen
| Touchscreen test
TouchScreen
| 27 SSP_Touchscreen
| Catch Touchscreen coordinates via SSP
WDT
| 28 Wdt_Interrupt
| Generate interruption at a Specific time via WDT
29 Wdt_Reset
| Reset chip at a Specific time via WDT
MCI
| 30 Mci_CidCard
| Test SD card module
USB
| 31 Usb_MassStorage
| Board is mapped to be moving storage in PC
32 Usb_VirtualCom
| Configure and make USB to be a virtual Com
IIS
| 33 IIS_Audio
| Test audio module
IIC
| 34_IIC_EEPROM
| Read and write external EEPROM via IIC
uC/OS
| 35_UCOSII_V2.54
| Ucos Realtime system example test
