标题: [求助]关于在ISS中调试程序的问题? [打印本页]
作者: yzj1109    时间: 2007-1-3 21:20     标题: [求助]关于在ISS中调试程序的问题?
我的NIOS的建立和NIOS/IDE中的存储器的设置与Atlera的文档介绍的一样,在Build all的时候也能通过,但是就是不能在ISS中仿真调试,说是不能装载,怎么回事?程序如下
#include <stdio.h>
#include <unistd.h>
#include <string.h>
#include "system.h"
#include "altera_avalon_timer.h"
#include "altera_avalon_timer_regs.h"
#include "alt_types.h"
#include "sys/alt_irq.h"
alt_u8 led=0;
alt_u16 cnter=0;
alt_u8 timer1_ok=0;
static void timer1_init()
  IOWR(SYS_CLK_TIMER_BASE,0,0);
  IOWR(SYS_CLK_TIMER_BASE,ALTERA_AVALON_TIMER_CONTROL_REG,0x0B);//continual count
  IOWR(SYS_CLK_TIMER_BASE, ALTERA_AVALON_TIMER_PERIODL_REG, 0x93E0);
  IOWR(SYS_CLK_TIMER_BASE, 3, 0x04);
  IOWR(SYS_CLK_TIMER_BASE, 1, ALTERA_AVALON_TIMER_CONTROL_CONT_MSK);
void timer1_isr(int context)
  IOWR(SYS_CLK_TIMER_BASE, 0, ALTERA_AVALON_TIMER_STATUS_TO_OFST);
  timer1_ok=1;
void main()
  int context=0;
  alt_irq_register(SYS_CLK_TIMER_IRQ,SYS_CLK_TIMER_BASE,timer1_isr);
  timer1_init();
  while(1)
    if(timer1_ok)
      timer1_ok=0;
      cnter++;
      if(cnter==20)
        cnter=0;
        led^=0xFF;
        IOWR(LED_PIO_BASE, 0, led);
Build的结果如下:../resource.c:55: warning: passing arg 2 of `alt_irq_register' makes pointer from integer without a cast
../resource.c:55: warning: passing arg 3 of `alt_irq_register' from incompatible pointer type
../resource.c:54: warning: unused variable `context'
../resource.c:77:51: warning: no newline at end of file
Info: (test.elf) 33 KBytes program size (code + initialized data).
Info:            16350 KBytes free for stack + heap.
Post-processing to create ext_flash.flash
Hardware simulation is not enabled for the target SOPC Builder system. Skipping creation of hardware simulation model contents and simulation symbol files. (Note: This does not affect the instruction set simulator.)
Build completed
作者: kzw    时间: 2007-1-4 22:27
这个和代码没有关系,其他的工程能够装载吗?
作者: 斌坚    时间: 2008-5-26 10:31
同样也是求教iss的使用问题,一直没有搞明白是怎么回事了,希望指教了!
