我的nios做debug时会出现:
Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00
Processor is already paused
Downloading 00000000 ( 0%)
Downloaded 26KB in 0.6s (43.3KB/s)
Verifying 00000000 ( 0%)
Verify failed between address 0x0 and 0x6533
Leaving target processor paused
等到flash下载又这样了:
#! /bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd H:/jhxla/logic/logic/software/hello_world_0/Debug
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --base=0x00000000 --end=0xfffff --reset=0x0 --inpu
t=hello_world_0.elf --output=cfi_flash.flash --boot=$SOPC_KIT_NIOS2/components/a
ltera_nios2/boot_loader_cfi.srec
# Programming flash with the project
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --base=0x00000000 cfi_flash.flash
Resetting and pausing target processor: OK
: Checksumming existing contents
00000000 : Reading existing contents
Checksums took 0.0s
00000000 ( 0%): Erasing
Erased 16kB in 0.0s
00000000 ( 0%): Programming
Program failed
# Creating .flash file for the datafile
$SOPC_KIT_NIOS2/bin/bin2flash --base=0x00000000 --location=0x0 --input=$SOPC_KIT
_NIOS2/examples/software/hello_world/hello_world.c --output=hello_world.flash
# Programming flash with the datafile
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --base=0x00000000 hello_world.flash
Checksummed/read 16kB in 0.6s
Erased 16kB in 0.0s
Program failed at offset 200
还没有解决吗??建议你去altera板块问问
