图1 Kintex7 GTX结构图
以发送方向为例,参看图2的发送方向的时钟分布图:图2 GTX 发送方向时钟分布图
Kintex7在进行链路速率切换时,主要有如下几种办法:图3 LPM模式下GTX结构图
DFE模式则提供更好的信道补偿,其能够支持高达12.5G的链路速率,并在信道插损大于8dB的场景下有良好表现。DFE和CTLE不同,它不会放大噪声和串扰,能纠正信道不连续引起的反射。它能自动利用AGC,CTLE,DFE和baseline wander cancellation来完成信道补偿,同时也支持CTLE手动模式。DFE模式下GTX的结构图如图4。图4 DFE模式下GTX结构图
8B/10频谱特性介绍图5 频谱图
GTX复位流程图7 GTX接收方向复位流程图
在发送方向,复位流程大致为:图8 GTX发送方向复位流程图
2. GTX配置介绍图9 DFE模式下CTLE的设置
除去上面的配置,影响GTX性能的还有RXCDR_CFG属性,其也只能通过DRP接口完成修改。具体推荐配置值参看表1。LPM/DFE | DATA RATE | RXOUT_DIV | REFCLK PPM | RXCDR_CFG(PRBS) | RXCDR_CFG(8B/10B) |
LPM | > 6.6G | 1 | (+/-) 200 | 72'h0B_0000_23FF_1040_0020 | NA |
<= 6.6G | 1 | 72'h03_0000_23FF_1020_0020 | 72'h03_0000_23FF_1040_0020 | ||
> 6.6G | 1 | (+/-) 700 | 72'h0B_8000_23FF_1040_0020 | NA | |
<= 6.6G | 1 | 72'h03_8000_23FF_1020_0020 | 72'h03_8000_23FF_1040_0020 | ||
> 6.6G | 1 | (+/-) 1250 | 72'h0B_8000_23FF_1020_0020 | NA | |
DFE | > 6.6G | 1 | (+/-) 200 | 72'h0B_0000_23FF_1040_0020 | NA |
<= 6.6G | 1 | 72'h03_0000_23FF_2040_0020 | |||
> 6.6G | 1 | (+/-) 700 | 72'h0B_8000_23FF_1040_0020 | ||
<= 6.6G | 1 | 72'h03_8000_23FF_2040_0020 | |||
> 6.6G | 1 | (+/-) 1250 | 72'h0B_8000_23FF_1020_0020 | ||
<= 6.6G | 1 | 72'h03_8000_23FF_1020_0020 | |||
LPM/DFE | 1.6G - 6.25G | 2 | (+/-) 200 | 72'h03_0000_23FF_4020_0020 | 72'h03_0000_23FF_1020_0020 |
2 | (+/-) 700 | 72'h03_8000_23FF_4020_0020 | 72'h03_8000_23FF_1020_0020 | ||
2 | (+/-) 1250 | ||||
LPM/DFE | 0.8G-3.125G | 4 | (+/-) 200 | 72'h03_0000_23FF_4010_0020 | 72'h03_0000_23FF_1010_0020 |
4 | (+/-) 700 | 72'h03_8000_23FF_4010_0020 | 72'h03_8000_23FF_1010_0020 | ||
4 | (+/-) 1250 | ||||
LPM/DFE | 0.5G-1.5625G | 8 | (+/-) 200 | 72'h03_0000_23FF_4008_0020 | 72'h03_0000_23FF_1008_0020 |
8 | (+/-) 700 | 72'h03_8000_23FF_4008_0020 | 72'h03_8000_23FF_1008_0020 |
