3、$sudo vim /etc/xinetd.conf并加入以下内容:
# Simple configuration file for xinetd
# Some defaults, and include /etc/xinetd.d/
defaults
# Please note that you need a log_type line to be able to use log_on_success
# and log_on_failure. The default is the following :
# log_type = SYSLOG daemon info
instances = 60
log_type = SYSLOG authpriv
log_on_success = HOST PID
log_on_failure = HOST
cps = 25 30
includedir /etc/xinetd.d
4、$sudo vim /etc/xinetd.d/telnet并加入以下内容:
# default: on
# description: The telnet server serves telnet sessions;it uses
# unencrypted username/password pairs for authentication.
service telnet
disable = no
flags = REUSE
socket_type = stream
wait = no
user = root
server = /usr/sbin/in.telnetd
log_on_failure += USERID
