/* do not clear AIE here, it may be needed for wake */
s3c_rtc_setpie(dev, 0);
free_irq(s3c_rtc_alarmno, rtc_dev);
free_irq(s3c_rtc_tickno, rtc_dev);
RTC实时时钟获得时间安函数
当调用read()函数时会间接的调用s3c_rtc_gettime()函数来获得实时时钟的时间。时间值分别保存在RTC实时时钟的各个寄存器中。这些寄存器是秒寄存器、日期寄存器、分钟寄存器、和小时寄存器。s3c_rtc_gettime()函数会使用一个struct rtc_time 的机构体来表示一个时间值
struct rtc_time {
int tm_sec;
int tm_min;
int tm_hour;
int tm_mday;
int tm_mon;
int tm_year;
int tm_wday; //这三个RTC实时时钟未用
int tm_yday;
int tm_isdst;
/* the only way to work out wether the system was mid-update
* when we read it is to check the second counter, and if it
* is zero, then we re-try the entire read
