一套完整的ARM交叉编译环境的搭建过程(6)
yuyang911220
2014-8-28 17:11
编译出错:
1)checking for suffix of object files... configure: error: in `/opt/embedded/build-tools/build-glibc':
configure: error: cannot compute suffix of object files: cannot compile
See `config.log' for more details
## Core tests. ##
configure:2363: checking build system type
configure:2377: result: x86_64-unknown-linux-gnu
configure:2397: checking host system type
configure:2410: result: arm-unknown-linux-gnu
configure:2439: checking for arm-linux-gcc
configure:2466: result: arm-linux-gcc
configure:2735: checking for C compiler version
configure:2744: arm-linux-gcc --version >&5
../glibc-2.13/configure: line 2746: arm-linux-gcc: command not found
configure:2755: $? = 127
configure:2744: arm-linux-gcc -v >&5
configure:2744: arm-linux-gcc -V >&5
configure:2744: arm-linux-gcc -qversion >&5
configure:2760: checking for suffix of object files
configure:2782: arm-linux-gcc -c conftest.c >&5
../glibc-2.13/configure: line 2784: arm-linux-gcc: command not found
configure:2786: $? = 127
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "GNU C Library"
| #define PACKAGE_TARNAME "c-library"
| #define PACKAGE_VERSION "(see version.h)"
| #define PACKAGE_STRING "GNU C Library (see version.h)"
| #define PACKAGE_BUGREPORT "glibc"
| #define PACKAGE_URL "http://www.gnu.org/software/c-library/"
解决方法:PATH=$PREFIX/bin
PATH ../glibc-2.13/configure BUILD_CC="gcc" CC=arm-linux-gcc --host=$TARGET --target=$TARGET --prefix=/usr --enable-add-ons --disable-profile --cache-file=config.cache --with-binutils=$PREFIX/bin/ --with-headers=$TARGET_PREFIX/include/ ,在配置前面加上PATH=$PREFIX/bin
PATH ,虽然你可能已加到bash.bashrc或/etc/profile,即将编译成的arm-linux-gcc设置了环境变量,用arm-linux-gcc -v检查发现已存在,但就是不好使,编译会报错(上述),故在配置前面加上此句。
