[代码] 主类
- package com.android.qu.antking.list;
- import android.app.Activity;
- import android.content.Context;
- import android.os.Bundle;
- import android.view.LayoutInflater;
- import android.view.View;
- import android.view.ViewGroup;
- import android.widget.BaseExpandableListAdapter;
- import android.widget.ExpandableListView;
- import android.widget.ImageView;
- import android.widget.TextView;
- import java.util.*;
- public class MyMain extends Activity {
- //author antkingwei
- private List<Map<String,Object>> parentList=new ArrayList<Map<String,Object>>();
- private List<List<Map<String,Object>>> childList = new ArrayList<List<Map<String,Object>>>();
- ExpendAdapter adapter;
- ExpandableListView exList;
- private String[] listName = new String[]{
- "我的好友","高中同学","大学同学","移动开发","网站建设","普通朋友"
- private String[] childTitle= new String[]{
- "丫宁","王八锐","小鸟","连超","董二丫"
- private String[] childMood= new String[]{
- "我喜欢王锐","我就是王八","我也喜欢王锐","上边一群傻帽","同楼上"
- private int[] headImage=new int[]{
- R.drawable.ning,R.drawable.rui,R.drawable.niao,R.drawable.lianchao,R.drawable.xiaoxiao
- public void onCreate(Bundle savedInstanceState) {
- super.onCreate(savedInstanceState);
- setContentView(R.layout.main);
- exList = (ExpandableListView) this.findViewById(R.id.expandableListView1);
- parentList =getParentList();
- childList = getChildList();
- adapter = new ExpendAdapter(MyMain.this, parentList, childList);
- exList.setAdapter(adapter);
- exList.setGroupIndicator(null);
- exList.setDivider(null);
- public List<Map<String,Object>> getParentList(){
- List<Map<String,Object>> list = new ArrayList<Map<String,Object>>();
- for(int i=0;i<listName.length;i++){
- Map<String, Object> curGroupMap = new HashMap<String, Object>();
- list.add(curGroupMap);
- curGroupMap.put("List", listName);
- return list;
- public List<List<Map<String,Object>>> getChildList(){
- List<List<Map<String,Object>>> list1 = new ArrayList<List<Map<String,Object>>>();
- for (int i = 0; i < listName.length; i++) {
- List<Map<String, Object>> children = new ArrayList<Map<String, Object>>();
- for (int j = 0; j <childTitle.length; j++) {
- Map<String, Object> curChildMap = new HashMap<String, Object>();
- children.add(curChildMap);
- curChildMap.put("Title", childTitle[j]);
- curChildMap.put("Mood", childMood[j]);
- curChildMap.put("Head", headImage[j]);
- list1.add(children);
- return list1;
复制代码
[代码] 自定义的Adapter
- import android.widget.Toast;
- public class ExpendAdapter extends BaseExpandableListAdapter {
- private LayoutInflater layoutInflater;
- private Context mContext;
- private List<Map<String,Object>> parentList = new ArrayList<Map<String,Object>>();
- public ExpendAdapter(Context mContext,List<Map<String,Object>> parentList,List<List<Map<String,Object>>> childList){
- this.mContext = mContext;
- this.parentList = parentList;
- this.childList = childList;
- layoutInflater = LayoutInflater.from(mContext);
- public Object getChild(int groupPosition, int childPosition) {
- // TODO Auto-generated method stub
- return childList.get(groupPosition).get(childPosition).get("Title").toString();
- @Override
- public long getChildId(int groupPosition, int childPosition) {
- return childPosition;
- @Override
- public View getChildView(int groupPosition, int childPosition,
- boolean isLastChild, View convertView, ViewGroup parent) {
- if(convertView ==null){
- convertView = layoutInflater.inflate(R.layout.childlist, null);
- final ImageView head=(ImageView)convertView.findViewById(R.id.headImage);
- head.setImageResource(Integer.valueOf(childList.get(groupPosition).get(childPosition).get("Head").toString()));
- final TextView title=(TextView)convertView.findViewById(R.id.title);
- title.setText(childList.get(groupPosition).get(childPosition).get("Title").toString());
- final TextView mood =(TextView)convertView.findViewById(R.id.mood);
- mood.setText(childList.get(groupPosition).get(childPosition).get("Mood").toString());
- return convertView;
- @Override
- public int getChildrenCount(int groupPosition) {
- return childList.get(groupPosition).size();
- @Override
- public Object getGroup(int groupPosition) {
- return parentList.get(groupPosition).get("List").toString();
- @Override
- public int getGroupCount() {
- return parentList.size();
- @Override
- public long getGroupId(int groupPosition) {
- return groupPosition;
- @Override
- public View getGroupView(int groupPosition, boolean isExpanded,
- View convertView, ViewGroup parent) {
- if(convertView==null){
- convertView=layoutInflater.inflate(R.layout.parentlist, null);
- final TextView list = (TextView) convertView.findViewById(R.id.list);
- list.setText(parentList.get(groupPosition).get("List").toString());
- @Override
- public boolean hasStableIds() {
- Toast.makeText(mContext,"nihao",Toast.LENGTH_SHORT).show();
- return true;
- @Override
- public boolean isChildSelectable(int groupPosition, int childPosition) {
- Toast.makeText(mContext, "这是第"+groupPosition+"组,第"+childPosition+"个", Toast.LENGTH_SHORT).show();
- return true;
复制代码
[代码] 主布局文件
- <?xml version="1.0" encoding="utf-8"?>
- <LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
- androidrientation="vertical"
- android:layout_width="fill_parent"
- android:layout_height="fill_parent"
- android:background="@drawable/back1"
- <ExpandableListView android:layout_height="wrap_content" android:id="@+id/expandableListView1" android:layout_width="fill_parent"></ExpandableListView>
- </LinearLayout>
复制代码
[代码] parentList布局
- <LinearLayout
- xmlns:android="http://schemas.android.com/apk/res/android"
- androidrientation="horizontal"
- android:id="@+id/parentList"
- android:layout_height="wrap_content">
- <ImageView
- android:layout_width="60px"
- android:layout_height="60px"
- android:src="@drawable/user_group"
- <TextView
- android:id="@+id/list"
- android:textSize="20px"
- android:layout_width="wrap_content"
- android:layout_height="wrap_content"/>
- </LinearLayout>
复制代码
[代码] childList布局
- <LinearLayout
- android:id="@+id/childList"
- <ImageView
- android:paddingLeft="20px"
- android:id="@+id/headImage"
- android:src="@drawable/icon"
- android:layout_width="50px"
- android:layout_height="50px"
- android:layout_marginBottom="5px"
- android:layout_marginRight="10px"/>
- <LinearLayout
- <TextView android:id="@+id/title"
- android:textSize="18px"
- <TextView android:id="@+id/mood"
- android:textSize="16px"
- </LinearLayout>
- </LinearLayout>
复制代码
希望本文对广大安卓开发者有所帮助,感谢阅读本文。更多安卓技术问题欢迎加群探讨:314230976,验证码:eec,不写验证不予通过哟~ |
