* request_dma - request and reserve a system DMA channel
* @dmanr: DMA channel number
* @device_id: reserving device ID string, used in /proc/dma
int request_dma(unsigned int dmanr, const char * device_id)
if (dmanr >= MAX_DMA_CHANNELS)
return -EINVAL;
if (xchg(&dma_chan_busy[dmanr].lock, 1) != 0)
return -EBUSY;
dma_chan_busy[dmanr].device_id = device_id;
/* old flag was 0, now contains 1 to indicate busy */
return 0;
} /* request_dma */
* free_dma - free a reserved system DMA channel
void free_dma(unsigned int dmanr)
if (dmanr >= MAX_DMA_CHANNELS) {
printk(KERN_WARNING "Trying to free DMA%d\n", dmanr);
return;
if (xchg(&dma_chan_busy[dmanr].lock, 0) == 0) {
printk(KERN_WARNING "Trying to free free DMA%d\n", dmanr);
return;
/* Set the DMA address for this channel
* This should not be called if a DMA channel is enabled,
* especially since some DMA architectures don't update the
* DMA address immediately, but defer it to the enable_dma().
extern void __set_dma_addr(unsigned int chan, void *addr);
#define set_dma_addr(chan, addr) \
__set_dma_addr(chan, bus_to_virt(addr))
