- startup_stm32f10x_ld_vl.s: for STM32 Low density Value line devices
- startup_stm32f10x_ld.s: for STM32 Low density devices
- startup_stm32f10x_md_vl.s: for STM32 Medium density Value line devices
- startup_stm32f10x_md.s: for STM32 Medium density devices
- startup_stm32f10x_hd.s: for STM32 High density devices
- startup_stm32f10x_xl.s: for STM32 XL density devices
- startup_stm32f10x_cl.s: for STM32 Connectivity line devices
cl:互联型产品,stm32f105/107系列
vl:超值型产品,stm32f100系列
xl:超高密度产品,stm32f101/103系列
ld:低密度产品,FLASH小于64K
md:中等密度产品,FLASH=64 or 128
hd:高密度产品,FLASH大于128
● Low-density devices: STM32F101xx, STM32F102xx and STM32F103xx
microcontrollers where the Flash memory density ranges between 16 and 32 Kbytes.
● Medium-density devices: STM32F101xx, STM32F102xx and STM32F103xx
microcontrollers where the Flash memory density ranges between 64 and 128 Kbytes.
● High-density devices: STM32F101xx and STM32F103xx microcontrollers where the
Flash memory density ranges between 256 and 512 Kbytes.
● XL-density devices: STM32F101xx and STM32F103xx microcontrollers where the
Flash memory density ranges between 512 and 1024 Kbytes.
● Medium-density Low-Power devices: STM32L15xx microcontrollers where the Flash
● Low Power Medium-density Plus devices:STM32L15xx and STM32L162xx
microcontrollers where the Flash memory density is 256 Kbytes.
● Low Power High-density devices: STM32L15xx and STM32L162xx microcontrollers
where the Flash memory density is 384 Kbytes.作者: 蓝小墨云 时间: 2014-11-28 16:00
