STM32使用FSMC控制NAND flash 例程(2)
yuyang911220
2015-1-18 11:07
void NAND_ReadID(NAND_IDTypeDef* NAND_ID)
uint32_t data = 0;
/*!< Send Command to the command area */
*(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = 0x90;
*(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = 0x00;
/*!< Sequence to read ID from NAND flash */
data = *(__IO uint32_t *)(Bank_NAND_ADDR | DATA_AREA);
NAND_ID->Maker_ID = ADDR_1st_CYCLE (data);//四个周期读取四个ID
NAND_ID->Device_ID = ADDR_2nd_CYCLE (data);
NAND_ID->Third_ID = ADDR_3rd_CYCLE (data);
NAND_ID->Fourth_ID = ADDR_4th_CYCLE (data);
复制代码
uint32_t NAND_WriteSmallPage(uint8_t *pBuffer, NAND_ADDRESS Address, uint32_t NumPageToWrite)
{//传入参数:写入数据,写入初始地址,要写几页
uint32_t index = 0x00, numpagewritten = 0x00, addressstatus = NAND_VALID_ADDRESS;
uint32_t status = NAND_READY, size = 0x00;
while((NumPageToWrite != 0x00) && (addressstatus == NAND_VALID_ADDRESS) && (status == NAND_READY))
/*!< Page write command and address */
*(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_AREA_A;
*(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_WRITE0;
*(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = 0x00;//添加此句
*(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_1st_CYCLE(ROW_ADDRESS);
*(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_2nd_CYCLE(ROW_ADDRESS);
// *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_3rd_CYCLE(ROW_ADDRESS);//原版有此句
/*!< Calculate the size */
size = NAND_PAGE_SIZE + (NAND_PAGE_SIZE * numpagewritten);//统计写入数目
/*!< Write data */
for(; index < size; index++)
*(__IO uint8_t *)(Bank_NAND_ADDR | DATA_AREA) = pBuffer[index];
*(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_WRITE_TRUE1;
/*!< Check status for successful operation */
status = NAND_GetStatus();
if(status == NAND_READY)
numpagewritten++;
NumPageToWrite--;
/*!< Calculate Next small page Address */
addressstatus = NAND_AddressIncrement(&Address);
return (status | addressstatus);
复制代码
读取函数同理修改
uint32_t NAND_EraseBlock(NAND_ADDRESS Address)
*(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_ERASE0;
// *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_3rd_CYCLE(ROW_ADDRESS);//两次即可
*(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_ERASE1;
return (NAND_GetStatus());
复制代码
fsmc_nand.h文件:
#define NAND_PAGE_SIZE ((uint16_t)0x0800) /* 512 bytes per page w/o Spare Area *///每页2K
#define NAND_BLOCK_SIZE ((uint16_t)0x0040) /* 32x512 bytes pages per block *///64个页
#define NAND_ZONE_SIZE ((uint16_t)0x0400) /* 1024 Block per zone *///1024个快
#define NAND_SPARE_AREA_SIZE ((uint16_t)0x0040) /* last 16 bytes as spare area */
#define NAND_MAX_ZONE ((uint16_t)0x0001) /* 4 zones of 1024 block */
复制代码
修改完即可实现512B至2K每页的变更
