标题: s3c2440的UART用法(2) [打印本页]
作者: yuyang911220    时间: 2015-2-26 13:17     标题: s3c2440的UART用法(2)
#define rGPBCON    (*(volatile unsigned *)0x56000010)      //Port B control
#define rGPBDAT    (*(volatile unsigned *)0x56000014)       //Port B data
#define rGPBUP     (*(volatile unsigned *)0x56000018)      //Pull-up control B
#define rGPHCON    (*(volatile unsigned *)0x56000070)      //Port H control
#define rGPHUP     (*(volatile unsigned *)0x56000078)       //Pull-up control H
#define rULCON0     (*(volatile unsigned *)0x50000000)     //UART 0 Line control
#define rUCON0      (*(volatile unsigned *)0x50000004)     //UART 0 Control
#define rUFCON0     (*(volatile unsigned *)0x50000008)     //UART 0 FIFO control
#define rUMCON0     (*(volatile unsigned *)0x5000000c)    //UART 0 Modem control
#define rUTRSTAT0   (*(volatile unsigned *)0x50000010)      //UART 0 Tx/Rx status
#define rUERSTAT0   (*(volatile unsigned *)0x50000014)      //UART 0 Rx error status
#define rUFSTAT0    (*(volatile unsigned *)0x50000018)      //UART 0 FIFO status
#define rUMSTAT0    (*(volatile unsigned *)0x5000001c)      //UART 0 Modem status
#define rUBRDIV0    (*(volatile unsigned *)0x50000028)     //UART 0 Baud rate divisor
//little endian
#define rUTXH0 (*(volatile unsigned char *)0x50000020) //UART 0 Transmission Hold
#define rURXH0 (*(volatile unsigned char *)0x50000024) //UART 0 Receive buffer
void Main(void)
      char ch;
rGPBCON = 0x015551;
rGPBUP  = 0x7ff;
rGPBDAT = 0x1e0;
rGPHCON = 0x00faaa;                //使用UART0功能
rGPHUP  = 0x7ff;
rULCON0 = 0x3;                    //设置UART0无奇偶校验,一位停止位,8位数据
rUCON0 = 0x245;                //PCLK为时钟源,接收和发送数据为查询或中断方式
//10  0100  0101
rUFCON0 = 0;                     //
rUMCON0 = 0;                    //
rUBRDIV0 = 26;                 //设置波特率,PCLK50MHz,波特率为115.2kHz
while(!(rUTRSTAT0 & 0x2));       //等待并判断发送缓存是否为空
rUTXH0 = 0xaa;                         //是空,则发送0xAA字节
while(1)
  while(!(rUTRSTAT0 & 0x1)); //等待并判断接收缓存是否准备好
  ch = rURXH0;                     //接收一个字节数据
              rUTXH0 = ch;                     //发送一个字节数据
switch(ch)             //根据所接收数据的不同,执行不同的程序
       case 0x11:              //LED
                            rGPBDAT |= 0x1e0;
       break;
            case 0x22:             //LED
              rGPBDAT &= 0x1f;
                    break;
       case 0x33:             //蜂鸣器不响
                            rGPBDAT &= 0x1e0;
                     break;
            case 0x44:             //蜂鸣器响
                            rGPBDAT |= 0x1;
                     break;
            default:                 //LED灭,蜂鸣器不响
                            rGPBDAT = 0x1e0;
                    break;
    下面是UART中断程序,它要比查询复杂一些,因为涉及到了中断处理,并且UART发送数据和接收数据是一个中断源。主程序循环体内不执行任何程序,都在UART中断程序内执行。当接收到0x55字节数据时,亮两个LED,当接收到其他数据时,发送该字节,并在发送部分执行亮4LED程序。
