标题: 读写SPI FLASH--驱动部分(8) [打印本页]
作者: yuyang911220    时间: 2015-2-27 09:10     标题: 读写SPI FLASH--驱动部分(8)
module_init(spi_init);
module_exit(spi_cleanup);
static uint8_t get_flash_status(void)
    uint32_t word, val;
    uint8_t ret;
     word = readw((void *)(spi_char.mem_virt+SPI_CTRL));
     word |= SPI_CTRL_SCGO; /* set cycle */
     word |= SPI_CTRL_ACS; /* Enable Atomic Cycle Sequence */
     word |= SPI_CTRL_SPOP;
     word &= ~SPI_CTRL_COP;
     word = word | SPI_CTRL_OPMENU_RDSR<<SPI_CTRL_COP_SHIFT; /* read */
     word &= ~SPI_CTRL_DBC;
     word = word | 0x00<<SPI_CTRL_DBC_SHIFT; /* read count=1 */
     word |= SPI_CTRL_DC;
      /* check the status */
     val = readw((void *)(spi_char.mem_virt+SPI_STATUS));
     while(val & SPI_STATUS_SCIP)
            val = readw((void *)(spi_char.mem_virt+SPI_STATUS));/* check the status */
     writew(word, (void *)(spi_char.mem_virt+SPI_CTRL));
     val = readl((void *)(spi_char.mem_virt+SPI_DATA0));
     SPI_DBG("get_flash_status:%08x/n", val);
     ret = (val&0xFF);
     word = readw((void *)(spi_char.mem_virt+SPI_STATUS));
     word |= SPI_STATUS_CDS; /* clear Cycle Done Status flag */
     word |= SPI_STATUS_BAS;  /* clear blocked flag */
     writew(word, (void *)(spi_char.mem_virt+SPI_STATUS));
     return (ret);
static uint8_t set_flash_status(uint8_t value)
     uint32_t word, var, val;
     var = value;
     writel(var, (void *)(spi_char.mem_virt+SPI_DATA0));
     word = word | SPI_CTRL_OPMENU_WRSR<<SPI_CTRL_COP_SHIFT; /* read */
     word = word | 0x00<<SPI_CTRL_DBC_SHIFT; /* write count=1 */
     var = get_flash_status();
     return (var);
static int is_bios_protection(void)
    unsigned int ret;
    ret = spi_char.bios_ctrl_addr & BIOS_NOPROTECTION;
    return (!ret);
static  int disable_bios_protection(void)
    unsigned int temp;
    struct pci_dev *pdev = NULL;
    if(is_bios_protection())
        temp = spi_char.bios_ctrl_addr | BIOS_NOPROTECTION;
        pdev = pci_get_device(SPI_VENDOR_ID, SPI_DEVICE_ID, NULL);
        if ( !pdev )
            SPI_ERR("%s:spi_char_init-Could not find pci device/n", DRIVERNAME);
            return (0);
        pci_write_config_byte(pdev, BIOS_CTRL, temp);
        spi_char.bios_ctrl_addr = temp;
    //release reference to device
    pci_dev_put(pdev);
    return (1);
static int  is_flash_protection(void)
    unsigned int var;
    var &= SPI_FLASH_PROTECTION;
    if(var || is_bios_protection())
        return (1);
    return (0);
static int disable_flash_protection(void)
    uint32_t word, var;
    uint8_t ret1, ret2;
    var &= ~SPI_FLASH_PROTECTION;
    ret1 = set_flash_status(var);
    ret2 = disable_bios_protection();
    if(ret1 != var || !ret2)
        return 0;
    return (1);
