功能类型 | 器件型号 | 说明 |
FPGA | XC6SLX16-2FTG256C | 14.5K Cell,MCBx2,I/Ox186,FTBGA260 |
DDR2 | MT47H64M16HR-3 | 1Gbit DDR2-667,16-Bit,FBGA84 |
Flash | W25Q16BVSIG | 32Mbit SPI Flash,SO8 |
Video | ADV7125JSTZ140 | 140MHz,24位色VGA输出,LQFP48 |
Audio | WM8731S | Audio Codec,I2S,SSOP28 |
Ethernet Phy | RT8211CL/RT8201EL | PHY,首选GE RGMII,备选FE MII,LQFP48 |
USB | CY7C68013A-56LTXC | USB2.0 SOC,16-Bit总线,8051核,QFN56(优先去除) |
UART | CP2102 | USB2.0 to UART Bridge,QFN28 |
SD Card | Standard SD Connector | SD卡槽,存储大量数据及Linux系统 |
PS2 | Standard PS2 Connector | PS2母头x2,连接鼠标键盘 |
Extend Con | PMOD Connector | PMOD排座若干,扩展一般功能模块 |
High Speed Connector | 高速连接器座,扩展高速信号模块 |
