标题: stm32 hard fault及堆栈探究 [打印本页]
作者: yuyang911220    时间: 2015-4-28 21:29     标题: stm32 hard fault及堆栈探究
hard fault
在调试RTC过程中,程序在主循环中执行两次后就进入hard fault的while(1)中断,keil显示调试窗口显示imprecise data bus error。完善RTC配置的时序也无济于事。网上查到一些hard fault的资料:
<STM32F10xxx Cortex-M3 programming manual>2.3.2对hard fault, bus fault等有具体的解释。keil的网站上http://www.keil.com/appnotes/files/apnt209.pdf也有概括性的解释:hard fault由bus fault, memory management fault或usage fault引起,前者有固定的仅次于NMI的高优先级;调试过程中出现的bus error属于bus fault,是取指或取值时的内存错误。ST论坛上对于hard fault的讨论,大牛们说:
是由于读写了一个非法位置,
“100% of the hard faults I've had are caused by variables accessing out of bounds. ”,
"The Cortex-M3 pushes fault context on to the stack (some 8 dwords as I recall), I think Joseph Yiu has some example of instrumenting this. This could should permit you to determine the faulting PC. With this and the register info, and a map file you should be able to zero in on what is going on.
                MRS     R0, PSP         ; Read PSP
                LDR     R1, [R0, #24]    ; Read Saved PC from Stack" 能看到出错的PC值倒是一个很方便的事情,不过还没试过。
还有若干链接,未及一一详看,先备着:https://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=https%3a%2f%2fmy%2est%2ecom%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fARM%20CortexM3%20STM32%2fHard%20Fault%20error&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000626BE2B829C32145B9EB5739142DC17E&currentviews=1147http://forums.arm.com/lofiversion/index.php?t13632.htmlhttps://my.st.com/public/STe2ecommunities/mcu/Lists/ARM%20CortexM3%20STM32/Flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2FARM%20CortexM3%20STM32%2FHardFault%20Exception%20Why%20oh%20why%21http://www.google.com/search?hl=en&q=Joseph+Yiu+hard+fault+exception+handler
论坛里大家都说到了Joseph Yiu,哪天要好好拜读一下他的CortexM3权威指南。
回头看自己的程序,从最简逻辑开始烧写运行,发现当增加到在Time_Display()时进入了hard fault。检查代码,函数中定义了一个char类型数组,用于存放需要显示到LCD上的时间字符串,但数组长度小于字符串长度。增大长度,就解决了问题。果然如大牛们所说,问题存在于数组越界。
之前我也犯过类似错误,可当时的现象是,串口实际发出的数据和数组中的数据相比,后半部分时对时错。当时的变量为全局变量,此处变量为局部变量。查到如下说明:“一个由c/C++编译的程序占用的内存分为以下几个部分: 1、栈区(stack)— 由编译器自动分配释放 ,存放函数的参数值,局部变量的值等。其操作方式类似于数据结构中的栈。2、堆区(heap) — 一般由程序员分配释放, 若程序员不释放,程序结束时可能由OS回收 。注意它与数据结构中的堆是两回事,分配方式倒是类似于链表,呵呵。3、全局区(静态区)(static)—,全局变量和静态变量的存储是放在一块的,初始化的全局变量和静态变量在一块区域, 未初始化的全局变量和未初始化的静态变量在相邻的另一块区域。 - 程序结束后有系统释放. 4、文字常量区—常量字符串就是放在这里的。 程序结束后由系统释放. 5、程序代码区—存放函数体的二进制代码。”全局变量储存在全局区,它的越界将影响其他变量的值,对程序运行不会有致命影响。局部变量在栈中,同时入栈的还有函数的回退地址,函数参数等。本次出现问题的代码段为:
[cpp] view plaincopy
