标题: STM32使用fsmc控制NOR flash 例程(3) [打印本页]
作者: yuyang911220    时间: 2015-4-29 16:48     标题: STM32使用fsmc控制NOR flash 例程(3)
void FSMC_NOR_Init(void)
  FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
  FSMC_NORSRAMTimingInitTypeDef  p;
  GPIO_InitTypeDef GPIO_InitStructure;  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
                         RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG, ENABLE);
  /*-- GPIO Configuration ------------------------------------------------------*/
  /* NOR Data lines configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_9 |
                                GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
                                GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 |
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  /* NOR Address lines configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 |
                                GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_12 | GPIO_Pin_13 |
  GPIO_Init(GPIOF, &GPIO_InitStructure);
                                GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
  GPIO_Init(GPIOG, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6;
  /* NOE and NWE configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
  /* NE2 configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  /*-- FSMC Configuration ----------------------------------------------------*/
  p.FSMC_AddressSetupTime = 0x05;     /*ADDSET  地址建立时间*/
  p.FSMC_AddressHoldTime = 0x00;    /*ADDHOLD 地址保持时间*/
  p.FSMC_DataSetupTime = 0x07;     /*DATAST 数据建立时间*/
  p.FSMC_BusTurnAroundDuration = 0x00;   /*BUSTURN 总线返转时间*/
  p.FSMC_CLKDivision = 0x00;      /*CLKDIV 时钟分频*/
  p.FSMC_DataLatency = 0x00;     /*DATLAT 数据保持时间*/
  p.FSMC_AccessMode = FSMC_AccessMode_B;   /*访问模式*/
  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM2;    // NOR/SRAM的存储块,共4个选项
  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;  //  是都选择地址和数据复用数据线
  FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_NOR;   // 连接到相应存储块的外部存储器类型
  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;  //存储器数据总线宽度
  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;   // 使能或关闭同步NOR闪存存储器的突发访问模式
                       //设置是否使用迸发访问模式(应该就是连续读写模式吧)
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;   //   设置WAIT信号的有效电平
  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;    // 设置是否使用环回模式
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState; // 设置WAIT信号有效时机
  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;  //   设定是否使能写操作
  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;   //    设定是否使用WAIT信号
  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;  // 使能或关闭扩展模式,扩展模式用于访问具有不同读写操作时序的存储器
                    // 设定是否使用单独的写时序
  FSMC_NORSRAMInitStructure.FSMC_AsyncWait = FSMC_AsyncWait_Disable;  //  设定是否使用异步等待信号
  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;  //  设定是否使用迸发写模式
  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;    //  设定读写时序
  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;    //
  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);        //
  /* Enable FSMC Bank1_NOR Bank */
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM2, ENABLE);        //
* Function Name  : FSMC_NOR_ReadID
* Description    : Reads NOR memory's Manufacturer and Device Code.
* Input          : - NOR_ID: pointer to a NOR_IDTypeDef structure which will hold
*                    the Manufacturer and Device Code.
* Output         : None
* Return         : None
void FSMC_NOR_ReadID(NOR_IDTypeDef* NOR_ID)
  NOR_WRITE(ADDR_SHIFT(0x05555), 0x00AA);
  NOR_WRITE(ADDR_SHIFT(0x02AAA), 0x0055);
  NOR_WRITE(ADDR_SHIFT(0x05555), 0x0090);
  NOR_ID->Manufacturer_Code = *(vu16 *) ADDR_SHIFT(0x0000);
  NOR_ID->Device_Code1 = *(vu16 *) ADDR_SHIFT(0x0001);
  NOR_ID->Device_Code2 = *(vu16 *) ADDR_SHIFT(0x000E);
  NOR_ID->Device_Code3 = *(vu16 *) ADDR_SHIFT(0x000F);
* Function Name  : FSMC_NOR_EraseBlock
* Description    : Erases the specified Nor memory block.
* Input          : - BlockAddr: address of the block to erase.
* Output         : None
* Return         : NOR_Status:The returned value can be: NOR_SUCCESS, NOR_ERROR
*                  or NOR_TIMEOUT
NOR_Status FSMC_NOR_EraseBlock(u32 BlockAddr)
  NOR_WRITE(ADDR_SHIFT(0x05555), 0x0080);
  NOR_WRITE((Bank1_NOR2_ADDR + BlockAddr), 0x30);
  return (FSMC_NOR_GetStatus(BlockErase_Timeout));
